  3. How to write bindkey
  • Replies 15
  • Subscribers 150
  • Views 23405
kalikrishna
kalikrishna over 14 years ago
 Hai all,
I want to create a bindkey, suchthat by using up and down keys on keyboard , the number of rows and columns for a Via will increase or decrease.
If anyone know, how to do this one...please do let me know
Thank You
T.Prasad
    I did a quick search in the community forums, and  found this post. It would also be worth saying which version of the software (as suggested in the Forum Guidelines) you're using, as vias are handled very differently between IC5141 and IC61 due to the change in the underlying database.
  • kalikrishna
     Hai Andrew,
                     I have seen the posts,attached you
                    Am using virtuoso 6.1.4 vertion. Those codes were not executed. and shows like below..
    changeVia2x1()
    (db:0x1456d493)
     Please, let me know, any other suggestions
    Thank You
    T.prasad
    As I said, vias are different in OA - they are not instances any more, but separate objects. Changing the code like this will make it a 2x1 via:
    procedure(CDSIC61changeVia2x1()
        foreach(fig geGetSelSet()
            when(fig~>objType=="stdVia"
                dbReplacePropList(fig
                    list(
                        list("cutRows" 'int 2)
                        list("cutColumns" 'int 1)
    I'm sure you can use this as a template for your own requirements.
  • kalikrishna
        I want to create a bindkey to convert M1_M2 via to M2_M3 via.
      please do let me know any suggestions .
    Thank You,
    T.Prasad
    You'd need to delete the original via (maybe capturing some of the key overrideParams from the viaHeader first) and then create a new one in the same place using dbCreateVia.
  • kalikrishna
    Thank you Andrew,
    To know the position of the previous via, i wrote as below
    point = fig~>xy
     I assigned the via with name "fig".
     But it shows  an error, "invalid parameter for the via definition".
    is it right?
    If wrong, please let me know suggestions.
    Thank You,
    T.Prasad
  • dmay
    dmay over 14 years ago
    Try fig~>origin.
    Depending on which version of 6.1 you are on, fig~>xy may not be available. Later versions of 6.1 allow you to use either. I've never understood why this was so inconsistent in the early versions.
    Derek
    Simple human oversight was probably the reason for the inconsistency. Remember that the db layer is a mapping from OA, and suspect the focus was on doing the mapping, rather than thinking about what other similar objects have inthe CDBA layer.
  • kalikrishna
    Thank you dmay,
                 I have another doubt.
    How to know the number of rows and columns of previous via.
    I used as below
    rows = fig~>Rows
    and then, i want to use this rows          value for the new via.
    but it shows, Invalid parameter for the ViaDef.
     please do let me know any suggestions.....
    Thank You,
    T.Prasad
  • dmay
    If fig is a stdVia, try using cutRows:
    fig~>cutRows = 3
    Derek
