  3. Delete layout terminals from database
  • Subscribers 150
  • Views 17166
mewi72
mewi72 over 14 years ago
After a cross-view check between schematic and layout some "ghost" terminals in layout were detected. There is no pin shape in layout and no label, but the dbOpenCellViewByType function with terminals~>name attribut displays this terminals for the layout view. Now I'm looking for a function which should compare the layout and the schematic terminals and delete the "ghost" terminals from the layout view. A big problem I think is the handling of busses. Every bus pin of the layout view will described as single terminal ("A<3>" "A<2>" "A<1> and so on), the pins from a bus in schematic view together ("A<3:1>").
Do you have some ideas?
Thank you, Melanie
  • Gopika
    Gopika over 14 years ago
    Hi Melanie,
    The following lines may help to find the ghost terminals in layout as compared to sch:
        cv = geGetEditCellView()
        lib = cv~>libName
        cell = cv~>cellName
        lay = dbOpenCellViewByType(lib cell "layout" "" "r")
        sch = dbOpenCellViewByType(lib cell "schematic" "" "r")
        ghostTerms = setof(x lay~>terminals !rexMatchList(x~>name sch~>terminals~>name))
    Regards
    venugopal Pabba
  • mewi72
    Hi Gopika,
    thank you for your answer. Your solution works, but there is a additional problem. I have busses in layout and schematic. In the schematic database a bus is represented only by a single terminal such as A<15:0>. In layout database, I can find 16 terminals for such a bus (A<15>, A<14> ...). I think I have to individualize the bus from the schematic at first.
    What do you mean?
    Best regards,
    Melanie
  • dmay
    dmay over 14 years ago
    You can use the command dbProduceMemName(name) to expand the bus.
    dbProduceMemName("a<0:9:3>")
    ("a<0>" "a<3>" "a<6>" "a<9>")
    You could also get all the schematic signal names that are associated with a terminal (signal object with a memTerms attribute) with something like this:
    sigNames = setof(x geGetEditCellView()~>signals x~>memTerms)~>name
    Then:
    ghostTerms = setof(x lay~>terminals !member(x~>name sigNames))
    Derek
  • mewi72
    Hi Derek,
    thank you very much! That works good!
    Best regards,
    Melanie
