  3. How to continue SKILL execution by diverting stderr to a...
  • Subscribers 150
  • Views 15567
How to continue SKILL execution by diverting stderr to a file?
kumarb
kumarb over 14 years ago
Hi Experts, When a program errors out, it just gets terminated with error message on stderr port. Now I am processing a list and want to print all the error output to a file and continue SKILL execution till end. How this can be possible? Example: procedure(errChk() foreach(elm list(1 “1” list(1) ) printf(“%f” elm) ) printf(“\nProgram execution completed”) ) When I run the program, I want to see “Program execution completed” printed in CIW and errors stored in some file. When I try myport=errport=outfile(“./error.txt”), then also it stops on first error. Thanks in advance for expert guidance. Best regards, Bhupendra
    errset is the key.
    procedure(errChk()
        let((redirectPort)
            redirectPort=outfile("./error.txt")
            when(redirectPort
                let(((errport redirectPort))
                    errset(
                        foreach(elm list(1 "1" list(1) )
                            printf("%f" elm) )
                        t
                    printf("Program execution completed\n")
                close(redirectPort)
    In this case, I'm wrapping the entire foreach in errset, and so it traps the error (the t as second argument tells it to print the error message still). The errport is redirected to a file - doing it with a let like this takes advantage of SKILL's dynamic scoping, and makes it "safe" because as the program unwinds, errport gets restored.
    If I move the errset to be around the printf, say:
    procedure(errChk()
        let((redirectPort)
            when(redirectPort
                errset(
                            printf("%f" elm)
                t
                close(redirectPort)
    Then error.chk will now have three errors in it.
    Hope that helps!
  • kumarb
    This works great!
    Thanks a lot.
    Best regards,
    Bhupendra
