  3. how to use geSwitch command
  • Subscribers 150
  • Views 16295
egxoner
egxoner over 14 years ago
hi i am new for the skill codes and trying to use geSwitch command. here is the usage of the command
geSwitch(
w_windowId
t_accessMode
d_instId
x_iteration
x_row
x_col
and here is what they mean
[B]w_windowId[/B] :Database ID of the window. --> i use getCurrentWindow( ) to get it.
[B]t_accessMode[/B] :Access mode. --> r (read) or a (append)
[B]d_instId[/B] :Database ID of the instance to switch into. --> [B] I dont know how to get it. This is my main question. [/B]
[B]x_iteration[/B]: Offset in the array of the instance. --> i know how to use it. used for arrayed instances.
[B]x_col and x_row[/B] :Column and row of the arrayed instance. --> i didnt understand what does it mean. if we define arrayed instances with x_iteration why do we need it? whats the diffrence?
as i said my main question is how to get [B] " d_instId " [/B] ???
regards
egx
    It seems a bit odd wanting to use a function to allow you to switch into an instance if you don't know how to find the instance id. How do you know it's doing what  you want to do? You can get an instance id by looking at a cellView and doing ~>instances - or by using dbFindAnyInstByName(), or indeed many other ways.
    What are you actually trying to  achieve in your SKILL code? How you would identify the instance is very dependent on what you're trying to do.
  • dmay
    dmay over 14 years ago
    There are several ways to get the instance id. I'm assuming since you are writing Skill code to do use the geSwitch command you are starting from a cellview or a selected set.
    1. To get a list of all the instance ids in the current cellview:
    instIds = geGetEditCellView()~>instances
    You would then then need to process this list to get the instance you want.
    2. To get the instance that is currently selected (assuming there is only one item selected):
    instId = car(selectedSet())
    You might want to confirm that instId~>objType == "inst"
    3. instId = dbFindAnyInstByName(geGetEditCellView() "myInstName")
    As for the row and column, you can set these to 0 when working on a regular instance (objType == "inst" as opposed to "mosaic").
    Derek
  • gennadygspsn
    gennadygspsn over 13 years ago
    Hi all,
    i am trying to use geSwitch to descend into schematic cell with custom  view name (schematic_postapr)
    the problem is geSwitch always gows to schematic view
     can i change it without changing viewNameList ?
  • Blues
    Blues over 13 years ago
    you can try dePush instead,
    dePush(list(nil 'instanceName car(geGetSelSet())~>name 'viewNameList "schematic_postapr") hiGetCurrentWindow())
  • gennadygspsn
    Thanks a lot
