  3. possible to do Analog simulation using High speed clusters...
  • Subscribers 150
  • Views 16116
possible to do Analog simulation using High speed clusters and Parallel processing?
AJ123654
AJ123654 over 14 years ago
Hello All,
I mostly use scripts to do Spectre simulation. We here have a high speed cluster and we would like to leverage it to reduce the speed time of simulation. So I have decided to join a course which uses openMPI or C ( not really sure about the language ) to parallelize the code.
Does anybody here have any experience on using cadence spectre simulation on high speed clusters? or if anybody can give me feedback on how useful this course would with respect to cadence spectre simulation.
Cheers
Anil
    Spectre already has an option called "APS" which gives access to enhanced performance without sacrificing accuracy, as well as being able to take advantage of multi-core machines which can give major performance increases overall. It also has capability (early access in MMSIM10.1 but enhanced in MMSIM11.1) which allow you to distribute parallel performance using multiple separate machines which can help in certain situations (contact Cadence to find out more about that).
    I doubt going on the course you describe would help, because it will be focused on how you write programs to take advantage of multi-core architectures. Not much you can do if you have existing executables - you'd need the source code and also understanding of how to make the algorithms parallelizable (which is by far the hardest bit compared with the mechanics of using any API) - so clearly that won't help. That's the part that Cadence has done for you.
    archive over 14 years ago
    As Andrew says, APS is the way to go if you can. I'm afraid I have nothing useful to add other than that APS is absolutely fantastic and we're now doing simulations we never would've dreamt of before. Thanks Cadence!
  • AJ123654
     Unfortunately I am not in a possition to influence decisions on License. But thanks for giving your feedback.
     I was thinking more on the lines of parallelizing data independent loops. Most of the time for Corner simulations, we end up running the loop for different corners which can be parallelized. Each iteration can be thrown on a seperate core and then the data integrated. I realize that Cadence does have support for distributed computing which can be used in such situations. Maybe I got to explore that.
    Any idea if SKILL is compatible with C? as these languages are used to work wth Clusters. I guess this is a very long shot!
     Cheers
    Anil
