  3. Help on skill code for to create wire for instance symb...
  • Subscribers 150
  • Views 20263
Help on skill code for to create wire for instance symbol
narendra046
narendra046 over 14 years ago
Hi Friends,
                  I have many standard cells & having Schematics .Each schematic only  have one instance symbol like AND or NAND or INV gates.I want to draw wire for every input & outpus of instance symbol & then I want to put pins for every wire.I tried to do this job by using skill code but I did not got it.. plz review my skill progrmme & plz let me know if any improvements in this... or
 If you have any idea plz let me know.........
procedure(MyInstancePins( libName viewName "tt" )
        let( ( d_libId d_cvId l_cellList l_instanceList )
d_libId = ddGetObj( libName )
l_cellList = setof(
                d_cell d_libId~>cells
                member( viewName d_cell~>views~>name )
foreach( d_cell l_cellList
     d_cvId = dbOpenCellViewByType( libName d_cell~>name viewName nil "a" )
     l_instanceList = setof( d_shape d_cvId~>shapes  d_shape~>objType == "InstPin" )
     foreach( d_InstPin l_instanceList
          dbCreateNet(cvId "wire" d_InstPin)
);foreach
      schCheck(cvId)
   dbSave( d_cvId )
   dbClose( d_cvId )
);foreach
);let
);;end of MyInstancePins
Narendra
  • dmay
    dmay over 14 years ago
    You'll need to do more than just create the net. You'll need to do a combination of the following commands:
    dbCreateNet
    dbCreateTerm
    schCreatePin : You'll need to pass this the cellview id of your pins (from your basic library?)
    If you want wires and labels, you'll need:
    schCreateWire
    schCreateWireLabel
    Sorry I don't have time to give you any sample code. Also, in 6.1.5, there is a feature to do this interactively:
    schHiCreateWireStubs() (Under the Create menu)
    Derek
  • narendra046
    Hi dmay,
                  Thanks for your response........I also tried with some commands which you sent. But I cant understand what inputs we have to give for to Run that commands..............
    May be whenever you have a time, plz spent for me to write coding....
    Narendra
  • Quek
    Quek over 14 years ago
    Hi Narendra
    Would you please use the original thread instead of creating multiple threads? Thanks. : )
    /forums/T/20508.aspx
    Best regards
    Quek
  • kamit
    kamit over 14 years ago
    I'd suggest Narendra to either request for skill training (basic and/or Advanced) or create a service request with Support.
    Check out available trainings at:
    http://www.cadence.com/training/in/Pages/default.aspx#lnktop
    Cheers,
    -kamit
