  3. Clearing a skill function definition within scheme (skill...
  • Subscribers 150
  • Views 16483
Clearing a skill function definition within scheme (skill++)
markbeck
markbeck over 14 years ago
Greetings all,
I'm trying to figure out a clean way to un-bind a skill function within skill++.  The typical way is to simply assign the name of the function to 'unbound
e.g. _foo = 'unbound
However, if I have a function defined in skill and I try in skill++ to de-assign it directly, I get the error:
*Error* eval: can't update SKILL function in Scheme via assignment
One really kludgy way that I've found that works is to re-assign the function within skill++ to a dummy function and then unbind it.
e.g.
(defun _foo () t)
  _foo = 'unbound
This works however it has the side effect that it prints a warning in the CIW:
*WARNING* (define): redefining SKILL function _foo to be Scheme variable
Does anyone know of a better way to achive the same result?
Mark
    I think putd('_foo nil) should do it.
  • markbeck
    That did it!
    Mark
