  3. Import csv data and jartListToWaveform()
  • Subscribers 150
  • Views 17025
ritterp
ritterp over 14 years ago
I apologize if this question has been asked before. In spite of its very basic nature I could not find any answer to the following problem on the cadence forums.
From a previous simulation I have a CSV textfile with time/value pairs
input.csv
0.00000000000e+00 -1.10875637805e+00
2.00000000000e-13 -1.10875643662e+00
 and the following skill code is used to import it:
pFILE=infile("input.csv")
if( pFILE then
lDATA=list()
time=0
value=0
while(gets( tLINE pFILE)
time=substring(tLINE 1 17)
value=substring(tLINE 19 18)
lDATA=cons(list(time value) lDATA)
wDATA=artListToWaveform(lDATA)
newWindow()
plot(wDATA)
close(pFILE)
Unfortunately my input.csv is pretty large (300K lines) and artListToWaveform(lDATA) crashes with a stack overflow. Moreover, the import itself is not as fast as I'd like it to be, but this is probably due to the substring function
Is there a more efficieny way for importing large csv files? Thank you in advance.
Regards, Phil
  • ritterp
    I've just came across getAsciiWave() which is much faster than my handmade solution, and, even more importantly, it does not crash at 300K lines.
    ... I knew there must be a simple solution ;-)
