  3. ocean OA writing outputsummary to a file
  • Subscribers 150
  • Views 15044
VictorB
VictorB over 14 years ago
Hi ,
When running ocean scripts, the result can be written to screen with the ocean command ocnxlOutputSummary().
How can this be written to a file, or just as in adexl, export to csv.
I couldn't find the command in the cadence help database.
rgds
Robert
    Robert,
    Here's a little bit of info from my OCEAN training class, where I describe how to do this:
    Currently the ocnxlOutputSummary does not support writing the summary
    information to a file. If you want to do this, the following wrapper around
    ocnxlOutputSummary may be used. This takes the same arguments as
    ocnxlOutputSummary, but adds an extra ?output argument to allow a file output
    handle to be specified:
    procedure(TrOcnxlOutputSummary(@key (output poport) @rest args)
     let(((poport output))
      apply(’ocnxlOutputSummary args)
    An example of using this:
    prt=outfile("summaryReport.txt")
    TrOcnxlOutputSummary(?output prt ?exprSummary t ?detailed nil)
    close(prt)
  • VictorB
    Thanks for your quick response.
    I plugged your script in and it is working !
     rgds
    Robert
