  3. Regarding Close & Purge Data using Skill
  • Subscribers 150
  • Views 4146
fazul
fazul over 14 years ago
Hi ,
Please advice me if you know how to do this.
I am using IC615, where in GUI of Virtuoso  we do File -> Close Data to close and purge data from the virtual memory.
I am trying to do this in my skill code. I suppose i have to use dbPurge() function.
My Question is how can i get the list of open data as show in the Close & Purge Data Form
Looking forward to any suggestions.
Thank you & Best Regards,
Fazul
    Fazul,
    dbGetOpenCellViews() and dbGetOpenBags() - also techGetOpenTechFiles() for completeness. Here's a rather elderly example:
    /* abPurgeLib.il
    Author     A.D.Beckett
    Group      Structured Custom, Cadence Design Systems Ltd.
    Machine    SUN
    Date       May 16, 1996
    Modified
    By
    A method of implementing the equivalent of dmPurgeLib in 4.4
    Two entry points:
    abPurgeLib(libName)
    abHiPurgeLib()
    SCCS Info: @(#) abPurgeLib.il 11/20/08.15:26:19 1.3
    *                     (abPurgeLib libName)                     *
    *            Purge everything to do with a library             *
    (procedure (abPurgeLib libName)
      /* close all the cellViews from this library name */
      (foreach cellView (dbGetOpenCellViews)
    	   (when (equal (dbGetq cellView libName) libName)
    		 (dbPurge cellView)))
      /* close any (?) tech files associated with the library */
      (foreach techFile (techGetOpenTechFiles)
    	   (when (equal (dbGetq techFile libName) libName)
    		 (techPurgeTechFile techFile)))
      /* close any property bags associated with the library */
      (foreach bag (dbGetOpenBags)
    	   (when (equal (dbGetq (dbGetq (dbGetq bag ownerObj) lib) name)
    			libName)
    		 (dbPurgeBag bag)))
      t)
    *                (abCreatePurgeLibForm choices)                *
    *                       Create the form                        *
    (procedure (abCreatePurgeLibForm choices)
      (let (libName)
           (setq libName (hiCreateCyclicField
    		      ?name 'libName
    		      ?choices choices
    		      ?prompt "Library Name"
    		      ?value (car choices)
           (setq abPurgeLibForm
    	     (hiCreateAppForm
    	      ?formTitle "Purge Library"
    	      ?name 'abPurgeLibForm
    	      ?fields (list (list libName 0:0 350:35 105))
    	      ?callback 'abPurgeLibCB
    *                        (abHiPurgeLib)                        *
    *        Human interface version of the library purger         *
    (procedure (abHiPurgeLib)
      (let (choices)
           (setq choices (dbGetq (ddGetLibList) name))
      (unless (boundp 'abPurgeLibForm) (abCreatePurgeLibForm choices))
      (putpropq (getq abPurgeLibForm libName) choices choices)
      (hiDisplayForm abPurgeLibForm)
      t))
    *                     (abPurgeLibCB form)                      *
    *            Interface from the form to abPurgeLib             *
    (procedure (abPurgeLibCB form)
      (abPurgeLib (getq (getq abPurgeLibForm libName) value)))
  • fazul
    Thanks Adrew for your quick response always.
    This should be enough :)
    Fazul
