  3. How to get write permission status
  • Subscribers 150
  • Views 19637
zhisong
zhisong over 14 years ago
To check cell editable information before open it, I try to use ddGetObj(lib cell view)~>isWritable
In my situation, I use design management software. Now before I check out the cell, of course I can't edit it, but the isWritable is t.
And I can find permission of all database  444. Is that a bug of IC5.1?
So any other way to check the editable info?
 Jason
  • Quek
    Quek over 14 years ago
    Hi Jason
    This is actually not a bug of IC5141. Virtuoso uses linux access() cmd to check for file permissions and as stated in "man access" (type "man access" in a terminal window), this cmd sometimes does not work properly for certain settings on linux NFS systems. You can do something like this:
    system("stat myfile | egrep Access > /tmp/check")
    inPort=infile("/tmp/check")
    fscanf(inPort "Access: (%d/" permission)
    close(inPort)
    printf("File permission is : %d\n" permission)
    I think there must be a better workaround than this. Maybe Andrew or Lawrence might have a better idea. : )
    Best regards
    Quek
  • zhisong
    Hi Quek,
    You're really a "DaNiu".
    I owe you a lunch. Wish can meet with you while you come to Shanghai next time.
    Jason
    Hi Jason,
    Generally when you are using design management, the view directory itself is still writable, but the files within are not (when checked in). Otherwise the DM system may not be able to alter the contents of the view.
    When you do: ddGetObj(lib cell view)~>isWritable you are retrieving the directory permissions, and so that's going to be writable regardless of whether it's checked in (even on a local disk). Instead do:
    ddGetObj(lib cell view "*")~>isWritable
    Which will give you the permissions of the "master" file (ie the file referenced in the master.tag - the "*" is the magic that does this) - e.g. the layout.cdb or sch.cdb file. This should genuinely be readonly if checked in.
    I've not seen the problem that Quek describes, but it would seem strange because then virtuoso would think it's editable and would then not attempt to check it out (assuming you were looking at the master file)
    Perhaps you can try what I suggest above and let us know how you get on.
  • zhisong
    Hi AB,
    You're correct, ddGetObj(lib cell view "*")~>isWritable represent the exact permission of view.
    Thanks a lot
