  3. How to force a vertical scrolling in a custum form
  • Subscribers 150
  • Views 15139
Eric L14
Eric L14 over 14 years ago
 Hi everybody,
I have created a custum form with hiCreateAppForm. This form contains for each cells of the layout a line containing labels, boolean buttons and cyclic fields.When my layout has many cells,the form has a vertical scroll bar.and some lines are not visible.
The skill code execute checks on layout cells and results are written in cyclic fields. I can see the progress of checks when they are done on visible lines. What I would like to do is making automatic scrolling in order to see the line correspondinf to the cell which is checked..
Is there a skill command to do that ?
Regards
Eric
  • Eric L14
     I found the solution of my problem with functions hiGetScrollBarInfo and hiSetScrollBarValue
    Regards
    Eric
