  3. Any way to get flat gds while pipo?
  • Subscribers 150
  • Views 15670
zhisong
zhisong over 14 years ago
 As we know, there is no option for get exact flat gds while pipo. And after search in support, all way is to saveAs and flatten "layout view" manually or SKILL-ly.
But I wonder whether we can realize it by write a poFlatCell code for "User-defined SKILL"
I try to use dbFlattenInst, but I don'n know how to catch instance id, like "ID" is cell id.
Wish I can get your comment.
 Jason
  • Quek
    Quek over 14 years ago
    Hi Jason
    Actually none of the po* functions for pipo will be able to help us in this. In IC61, we can use poPreTranslate function to flatten the design before stream-out. The next alternative for you would be to use Assura's outfile function in "flat" mode. This would also allow you to generate a flat gds easily.
    Best regards
    Quek
  • zhisong
    OK, Quek. Then I think I have to back to flatten it in cdb, because I'm using IC5.1
     Thanks for your idea.
