  3. VXL layout links to schematic
  • Views 16680
frogconsultant
frogconsultant over 14 years ago
Dear All,
As I am concerned I have not seen this point answered yet or I may not ask the correct question in the forum search.
Using VXL flow, I am selecting a couple of ports in the layout and of course the corresponding selected ports are selected in the schematic. I am able to grab the list of selected instance from the open layout window but in the same script I am not able to see how I could link to the corresponding schematic window in order to grap the selected instances list.
Is there a way after selected the layout ID window to also find the corresponding schematic ID window (VXL)?
Best regards,
Fabian
  • Quek
    Quek over 14 years ago
    Hi Fabian
    Are you looking for this function?
    srcID=lxGetLXInfo("srcView" layoutID)
    Best regards
    Quek
  • frogconsultant
     Thanks Quek.
     This was exactly what I was looking for. I looked in startFinder() but can not find the proper description to find the common. May you give me your tips to find this common or is it purely experiences?
  • Quek
    Hi Fabian
    Actually I don't use the finder because it gives too little information. I always use the pdf files of the appropriate documentations. For this case, actually I know the function so I guess it is from experience. : )
    Best regards
    Quek
    Fabian,
    Also you can search for the function name in cdnshelp. The finder is only intended to be a short one line reminder of the name, arguments, and return value - the full documentation is in cdnshelp.
