  3. Analog design environment save directory change
  • Subscribers 150
  • Views 15362
corrado123
corrado123 over 14 years ago
is there any way to automatically modify the state save directory of the analog design environment with a path depending from the Library name of the design from which ADE has been started?
i.e. I start ADE from schematic in Library Alibrary_name and I want the state save directory of the ADE set to ./Alibrary_name/artist_states
when i start ADE from schematic in Library Blibrary_name I want the state save directory of the ADE
set to ./Blibrary_name/artist_states
Corrado
    Corrado,
    I was going to suggest that this might be possible to use the  asimenv.startup sessInitTrigFunc cdsenv variable to specify a function to call when ADE starts up which changes the path for save state (the asimenv saveDir cdsenv var), but wouldn't it just be better to save the ADE states into cellViews in the library instead?
  • corrado123
     Many thanks for your reply.
    Yes, the easy way is to save the state as a Cellview, but I need to separate schematics database from artist_states so I have to follow the other approach.
    Corrado
