  3. How to set the orientation of a given mosaic object?
  • Subscribers 150
  • Views 17058
cessej
cessej over 14 years ago
I was able to set the orientation of instances using instObj~>orient="R90" but I can't do it for mosaic object.
I search the forum but I can't find the answer.
Thank you.
  • StefanSL
    StefanSL over 14 years ago
     Hi cessej,
    the appropriate key for the orientation of your mosaic-object is "tileArray";
    unfortunately, mosaic_id~>tileArray cannot be modified by a skill-command.
    There's an API-function dbSetTileArray that could be used for self
    defined  enhancements.
    I assume the only way to modify the orientation by skill is, to gather all
    required informations from the existing mosaic, delete the mosaic and
    create a new mosaic applying the modified parameters.
    kind regards
    Stefan
  • dmay
    dmay over 14 years ago
    If you have the mosaic id, then you can do this:
    ;Store the current xy of the mosaic (assuming mo contains the mosaic ID)
    xy = mo~>xy
    dbMoveFig(mo geGetEditCellView() list(0:0 "R90"))
    mo~>xy = xy
    Derek
  • cessej
    Thanks for the help. I think this solution really help at some point. Is it applicable when edit-in-place or do I still need to transform the bbox?
  • dmay
    I think it should still work for edit-in-place. We are simply applying a tranform that contains a rotation. However, since we cannot specify the reference point for the rotation, we just capture the xy and reset it afterwards. I haven't tested it, but I think this will be unaffected in eip.
    Derek
