  3. dbCreateVia() questions: default versus override params
  • Views 18161
frogconsultant
frogconsultant over 14 years ago
I am building a procedure using the parameters of the object Via. I am changing the overrideParams of concern in order to increase or decrease the parameter value. The issue I have and I am not understanding is that when I am arriving to the default value of the parameter after decrease the value with the overrideParams, I can not get out i.e. increase or decrease this parameter anymore as describe in my little procedure.
Does someone have the same issue?
How could I get out of this default value lock?
procedure( viasColumnsDown()
    viewLyId = geGetEditCellView()
    Selecedtset = geGetSelectedSet()
    foreach( Obj Selecedtset
        if( (Obj~>objType == "stdVia" ) then
            paramNames='("cutLayer" "cutWidth" "cutHeight" "cutRows" "cutColumns"
                "cutSpacing" "layer1Enc" "layer2Enc" "layer1Offset" "layer2Offset"
                "originOffset" "imp1Enc" "imp2Enc" )
            default = mapcar('list paramNames Obj->viaHeader->viaDef->params)
            override = Obj->viaHeader->overrideParams
           v1 = dbCreateVia(viewLyId via12Id Obj->xy "R0"
                list(list("cutColumns" cadr(assoc("cutColumns" override))-1)  ))
            dbDeleteObject( Obj )
        ) ;if
        if( (v1 != nil) then
            geSelectObject( v1 )
        ) ;if
    );foreach
);procedure
This post could be a complement of similar post but as it is a new question I have posted as a brand new post.
Thanks in advance for your help,
Fabian
    Fabian,
    Try this:
      let((selectedSet paramNames default override newColumns)
        selectedSet = geGetSelectedSet()
        foreach( Obj selectedSet
            when( Obj~>objType == "stdVia"
                ; Convert defaults to an assoc list
                newColumns=
                    ; Constrain the value to be greater or equal to 1
                    max(1
                        cadr(
                            ; If there's a value in the overrideParams, use that,
                            ; otherwise take the default
                            assoc("cutColumns" override) ||
                            assoc("cutColumns" default)
                        )-1
                ; Replace the property, rather than deleting the via and re-adding
                dbReplaceProp(Obj "cutColumns" 'int newColumns)
            ) ; when
        );foreach
        t
    );procedure
  • frogconsultant
     Dear Andrew,
    I like you approach better than mine :-)
    ;    println("CDown")
    ;                println(cadr(assoc("cutColumns" override)))
                tfId = techGetTechFile(ddGetObj("lbc7"))
                   via12Id = techFindViaDefByName(tfId "via12_OA")
                if( (cadr(assoc("cutColumns" override)) == nil) then
                    v1 = dbCreateVia(viewLyId via12Id Obj->xy "R0" list(
                        list("cutRows" if(cadr(assoc("cutRows" override))!=nil then cadr(assoc("cutRows" override)) else
                        cadr(assoc("cutRows" default))))
                        list("cutColumns" 1.0)
                        list("layer1Enc" '(0.1 0.1)) ))
                else
                ) ;if
            ) ;if
            ) ;if
        );foreach
    );procedure
    A bit more complex. Thanks for the simplify code.
    Fabian
