  3. Forms Description
  • Subscribers 150
  • Views 16256
Forms Description
frogconsultant
frogconsultant over 14 years ago
 Hi All,
I am using the samples for the Cadence online document from Product version 31.09 of  November 2009. The sample I am referencing on this post is the one on page 642/643. While I am using as it is i.e.:
;;; creating the File Name field
trFileNameField = hiCreateStringField(
    ?name 'trFileNameField
    ?prompt "File Name"
    ?defValue ".cshrc"
    ?callback "trDoFieldCheckCB( hiGetCurrentForm() )"
    ?editable t
;;; checking if the file exists
procedure( trDoFieldCheckCB( theForm )
    if( isFile( theForm->trFileNameField->value )
        then
            println("File exists")
            t
        else
            println("File Does Not Exist--Try Again")
            nil
        ) ;if
) ; procedure
;;; creating the form
trFileForm = hiCreateAppForm(
    ?name ?trFileForm
    ?formTitle "File Form"
    ?callback ?trFileFormCB
    ?fields list( trFileNameField )
    ?unmapAfterCB t
procedure( trFileFormCB( theForm )
    if( trDoFieldCheckCB( theForm )
        then
            hiSetCallbackStatus( theForm t )
            hiHighlightField( theForm 'trFileNameField 'background )
            view( theForm->trFileNameField->value )
        else
            hiSetCallbackStatus( theForm nil )
            hiHighlightField( theForm 'trFileNameField 'highlight )
        ) ; if
) ; procedure
;;; displaying the form
hiDisplayForm( 'trFileForm )
I got
*Error* hiFormDone: argument #1 should be a defstruct (type template = "r") - ?trFileForm
when I click with the mouse on the Ok button and almost identical messages on anywhere else on the form.
Am I missing something obvious to use this simple skill or should I call the form differently as specified in Cadence document?
Thanks a lot for your help,
Fabian
  • skillUser
    skillUser over 14 years ago
    Bonjour Fabian,
    I can see two "typos":
    ?name ?trFileForm
    Should be:
    ?name 'trFileForm
    And:
    Should be:
    ?callback 'trFileFormCB
    However, I have not tried any of this code, this is just by inspection...
    Hopefully this will help!
    Lawrence.
  • frogconsultant
    Thanks Lawrence to see the typos. It solved completly the issue.
    It is unfortunate that Cadence samples could not be skill bug free :-)
    Cheers, Fabian
    Fabian,
    I looked in the PDF you mention (skuiref.pdf) and it does have 'trFileForm and 'trFileFormCB . So they are correct. The trouble is that sometimes when you copy and paste such code into an editor, the fact that there are numerous different quote characters can mean that they get translated into an unknown character (?) by the editor you're using. Looking at the document, you'll see a little further up in the definition for trFileNameField a single quote is used - and it's slightly different from the single quote on the hiCreateAppForm() call. So I think that's the likely cause.
