  3. envSetVal "labelHeight" (IC6) from .cdsinit
  • Replies 8
  • Subscribers 150
  • Views 6918
stuso
stuso over 14 years ago
 hi guys,
i can do the following in my ciw/virtuoso window:
envSetVal( "layout" "labelHeight" 'float 0.05 )
and using envGetVal it seems to have worked ok.
However when i add the same line to my .cdsinit andstart a new cadence session it does not sseem to have any effect. I'm sure my .cdsinit is being loaded as i have some print statements in there at the start and end of the .cdsinit.
Stu
FYI: i am trying to set the default label size for pins for when i generate/update with XL
  • stuso
     Hi, i just inserted some more testing before and after i load this, so this is now in my .cdsinit:
        ;; TEST
        labelSizeOne=envGetVal( "layout" "labelHeight" )
        printf("label height one is:%L\n" labelSizeOne)
        ;;END TEST
        ;; TEST
        labelSizeTwo=envGetVal( "layout" "labelHeight" )
        printf("label height two is:%L\n" labelSizeOne)
        ;;END TEST
    And when i look in my log file after a cadence restart i see:
    label height one is:0.2
    label height two is:0.2
     So i am now very sure i have an actual issue and that its not being overwritten by another following.cdsinit or skill that i was unaware of.
    Stu
  • dmay
    dmay over 14 years ago
    I'm not sure why this is happening. I can see the same problem. You can get what you want by setting the variable in your .cdsenv file. That is what it is intended for. The envSetVal is to be used if you are already in Cadence, but if you want a default changed at startup, it is best to use the .cdsenv file. The syntax is simply this:
    layout labelHeight float 0.05
    Derek
    Stu,
    I see what you see - if I used envGetVal, envSetVal, envGetVal together in the code, the two envGetVal's return the same thing. However, if after the .cdsinit has loaded, I do the envGetVal, I do see it has changed.
    I tried the same thing with other float cdsenv settings, and see the same behaviour - but tried with other tool.partition values and that works fine. I'm guessing there's some trigger which is not making the update until the UI has returned - I don't know why.
    However, as I said, for me this appears to overall be working - I set it in the .cdsinit, and I can see the effect if I query in the CIW, and also when I bring up the layout window and try to create a label - it's honouring my change.
  • stuso
     Hi Derek,
    i have been trying to put all my settings in the one file, infact at this time i do not have a .cdsenv at all (i use envSetVal in the .cdsinit for all my environment variable settings).
    Is this bad practice?
    Hi Andrew, if it makes any difference, i am on: IC614-ISR11
    Thanks guys
    Stu
     Stu,
    I see the same behaviour in IC5141 and in the latest IC615 hotfix. So I don't think its version-specific.
    However, as I mentioned, once set it the .cdsinit it does actually seem to change - it's just the print statement that follows it which is reporting the wrong thing.
    Something does appear wrong here - I would suggest you file a service request and then we can look at it properly and get a CCR filed (although hopefully the problem is just cosmetic, if it really is just delaying when the change is recognized until the SKILL top level returns; i.e. the UI is waiting for a response). If it's not picking it up at all for you, then we need to investigate why it works for us and not for you - an SR would be best for that too.
    Cheers,
  • dmay
    I wouldn't say it is bad practice, just a matter of preference. There are so many variables you can set to customize forms, tools, windows, etc, that the .cdsenv file is a convenient place to put them. The .cdsinit file is a great place to put skill code you want to run at startup (load personal bindkeys, display the library manager, etc). Some of the options forms have a convenient feature to load/save the .cdsenv file, so by having your settings in the .cdsenv, you can quickly revert back to your personal defaults.
    Derek
  • stuso
     Hi guys, i should point out i had a typo in my .cdsinit testing, i was printing the same variable twice, it should have read:
        ;; TEST
        ;;END TEST
        ;; TEST
        printf("label height two is:%L\n" labelSizeTwo)
        ;;END TEST
     And now CDS.log shows:
    label height two is:0.05
    However i ave just noticed in my CDS.log that this line follows the above:
    \o loading vars from .cdsenv for tool layout
    Surely this means my changes are being overwritten by the tools .cdsenv?
    I am now questioning my undestanding of ordering sequence of .cdsinit & .cdsenv but perhaps this deserves a new topic discussion of its own.
    Stu
    Stu,
    I'm a bit embarrassed that I didn't notice that typo! I stared at it for a while and clearly didn't spot that...
    Anyway, the .cdsenv is definitely loaded before the .cdsinit, so I can only imagine that there's an envLoadFile or envLoadVals (or maybe leEnvLoad) call in the .cdsinit somewhere (or in a file loaded from the .cdsinit)?
