  3. OCEAN script that identifies max settings
  • Subscribers 150
  • Views 17382
Adrian P
Adrian P over 14 years ago
I am a student new to OCEAN. I am trying to optimize the gain of a multi-stage differential amplifier by finding the best combination of transistor parameters and biasing voltages. So far I have been using the following two approaches:
1) a. Run a parametric analysis of multiple variables using ADE
b. Plot gain of all outputs on a single graph
c. Visually identify the best curve and look at what combination of parameters produced it.
2) a. Run an OCEAN script that does the same parametric analysis and writes the output to a text document
b. Take the text document and extract the data
c. Analyze the data in MATLAB to identify the best curve and the settings that produced it
Ideally, I would like my OCEAN script to identify the max gain, and more importantly the settings that produced it. I know that the max command could be used to determine the max gain, but I can't figure out how to get the settings that produced the max. Any suggestions?
Thanks!
Here is the script I am referring to in approach 2) :
simulator('spectre)
design("/home/po/pope0828/simulation/ocean_testing/spectre/schematic/netlist/netlist")
resultsDir("/home/po/pope0828/simulation/ocean_testing/spectre/schematic")
modelFile('("/home/mo/morris/g045/gpdk045/../models/spectre/gpdk045.scs" "mc"))
analysis('ac ?start "1M" ?stop "100M" )
desVar("width" 200n)
desVar("fingers" 1)
desVar("voltage_a" 1.1)
desVar("voltage_b" 1.1)
temp(27)
paramAnalysis("width" ?values '(1.5e-07 1.6e-07 1.7e-07 1.8e-07 1.9e-07 1e-06) paramAnalysis("fingers" ?values '(1 2 3 4 5 6 7 8 9 10) paramAnalysis("voltage_a" ?values '(0.6 0.7 0.8 0.9 1.0 1.1 1.2) paramAnalysis("voltage_b" ?values '(0.6 0.7 0.8 0.9 1.0 1.1 1.2)))))
paramRun()
ocnPrint( ?output "./myoutput.txt" db20(VF("/net08")/VF("/net7")) ?precision 16 ?numberNotation 'scientific ?from 1M ?to 100M ?step 1M )
  • ebecheto
    ebecheto over 14 years ago
     Since VF("/net08")/VF("/net7") is a set of complex values, you just need to do :
    ymax(mag(VF("/net08")/VF("/net7")))
    I think you don't need more. But if you do,  ask for more
  • Adrian P
    Thanks for the response ebecheto.
    When I use the ymax command it finds the maximum value which is very useful, but it does not give me the settings that produced that maximum value. Ideally, I would like to know the maximum value and the settings that produced it.
    Perhaps xmax is what you want then? (note, I did not read through your entire question)
  • Adrian P
    Thank you Andrew.
     I will experiment with xmax over the weekend and report back.
  • Adrian P
    It turned out that I needed to use combinations of ymax(xmax(xmax(wave))) to get the different parameter values that proudeced the maximum.
    Thanks guys.
