  3. How to evaluate passed parameter with conditional CDF Parameter...
  • Subscribers 150
  • Views 16172
How to evaluate passed parameter with conditional CDF Parameter Instance Label
dNora
dNora over 14 years ago
We use conditional CDF parameter Instance label to hide CDF parameter under certain condition like m=1 similar to CCScondLabel.il script. But it doesn't evaluate passed parameter correctly.
cdfgData = cdfGetInstCDF(inst)
 if( atoi(cdfgData->stripes->value) == 1 then ""
 else
    when( atoi(cdfgData->stripes->value) > 1
          sprintf(nil "s = %s" cdfgData->stripes->value)
     ) ; when
 ) ; if
Passed parameter is displayed as nil using above script.
From CIW: cdfgData->stripes->value  returns  "[@s:%:1]"
How do I update the script to perform conditional CDF parameter that works with both passed parameter and regular string?
 I'm using IC6.1.5 version.
Any input would be highly appreciated!
Nora
  • dNora
    I'm presuming at this point whatever I'm asking is not possible unless someone responds.
  • skillUser
    skillUser over 14 years ago
     Hi Nora,
    I'm a bit confused as to what you have - the "from CIW" string suggests that this is an NLP parameter, as opposed to say just a string parameter which would be usual for a CDF parameter.  What do you expect atoi() will do with such a string?  Perhaps in the code you could test the value to see if it contains "%" or ":" and treat it differently than if it contained just a number?  The parseString() function could be useful here, give the second argument as ":", and perhaps use this as input to repeat pasreString again with "]", and then the last item should be the number.
    Hopefully this helps, but if not, can you share more details so that we can understand what you have exactly, and what you are trying to achieve?
    regards,
    Lawrence.
  • dNora
     Hi Lawrence,
    I have an  ILExpr label that displays stripes parameter when it's value more than 1 and hides it when it's equal to 1.
    stripes parameter itself is string type CDF parameter. Code I have used is very simple:
             if( inst->stripes == "1" then "" else strcat("s=" inst->stripes)
    But the problem is when parameter passed for stripes through hierarchy then it displays expression like s=[@s:%:1]  instead of displaying it's passed value from hierarchy. How do I modify above code to handle passed parameter?
    Nora
