  3. How do I find the intersection of a list within a range
  • Subscribers 150
  • Views 16451
johntling
johntling over 14 years ago
I want to find out whether my pin text coordinates is contained within a given rectangle pin coordinates (i.e. contained within the pin), how would I do this if I got the centerBox of the pin text coordinate, and then try to see whether that falls within the range of the pin coordinates.
  • skillUser
    skillUser over 14 years ago
     Hi John,
    I'm not sure if there is a generic point-based function for this, there are the various dbLayer* prefix functions, like dbLayerInside, and there is also a leIsPointInsideFig function, but these work on shapes.  However, having said this, I would have thought that the test is relatively simple, the point's X has to be >= the box lower left X, and <= the box upper right X AND the point's Y has to be >= the box lower left Yand <= the box upper right Y.  Something like the following I think:
    procedure(CCSisPointInBox(pt box "ll")
      when(geCoordp(pt) && isBBox(box)
        when( xCoord(pt) >= xCoord(lowerLeft(box))  &&
              xCoord(pt) <= xCoord(upperRight(box)) &&
              yCoord(pt) >= yCoord(lowerLeft(box))  &&
              yCoord(pt) <= yCoord(upperRight(box))
            t
        ); when
      ); when
    ); procedure CCSisPointInBox
    I think that the above code does the trick?  It returns 't' if the conditions are all met, and nil otherwise, or if either the point is not a valid point, or the box is not a valid bounding box, as decided by the geCoordp and isBBox functions respectively.  The isLocation function could be used for the point, but I think that geCoordp is slightly more descriptive of what the function is used for.
    Best regards,
    Lawrence.
  • skillUser
     By the way, strictly speaking this code is really too simplistic since I use ">=" and "<=" for comparing what might be floating point numbers that could well be considered the same within a specific tolerance yet reported as being otherwise (e.g. they are not the same down to the 12th decimal point), so treat this as an algorithm, rather than a complete or correct solution for this reason.  It is generally not safe to use "==" when comparing floating point numbers!
    Lawrence.
  • johntling
    Thanks for your help Lawrence!
