  3. How to get individual pin coordinates when multiple pins...
  • Subscribers 150
  • Views 14849
How to get individual pin coordinates when multiple pins have the same name
johntling
johntling over 14 years ago
I have  several pins using the name "vssa",
I've implemented a sort routine to sort the list of pin using the below code:
 procedure( sortPin(cv)
 let( (symSelBoxShp pinShpList tableName pinTable pinShpCenterPt
      topPinShpList sortedTopPinShpList sortedTopPinTerNameList)
  tableName = sprintf(nil "%s_layout_pinLocs" cv~>cellName)
  pinTable = makeTable(tableName nil)
  pinShpList = setof(x cv~>shapes
                     x~>lpp == '("METAL5" "pin") && x~>pin)
  foreach(pinShp pinShpList
     pinShpCenterPt = centerBox(pinShp~>bBox)
       case(CCSPinLoc1(pinShpCenterPt)
            ("top"
           topPinShpList = cons(pinShp topPinShpList)
           pinShp->loc = "top"
             (t
             error("unexpected input")
          );case
)     ; foreach
  sortedTopPinShpList = sort(topPinShpList 'CCSSort)
   sortedTopPinTerNameList = foreach(mapcar x sortedTopoPinShpList list(x~>pin~>term~>name x~>pin~>term~>direction x~>pin~>term~>pins~>fig~>bBox))
  pinTable["top"] = sortedTopPinTerNameList
  pinTable
); let
); procedure
procedure(CCSPinLoc1(pinShapeCenterPt "l")
 prog( (topY )
topY = 5377
roundY = round(yCoord(pinShapeCenterPt))
     if((roundY == topY || roundY == topY-1 || roundY == topY+1) then return("top")
);prog
);procedure
procedure(CCSSort(shp1 shp2)
 prog( (pinShp1CenterPt pinShp2CenterPt)
     pinShp1CenterPt = centerBox(shp1~>bBox)
     pinShp2CenterPt = centerBox(shp2~>bBox)
  case(shp1->loc
       ("top"
        if(xCoord(pinShp1CenterPt) < xCoord(pinShp2CenterPt) then t
         else nil
         );if
       ("bottom"
         else nil
         );if
       ("left"
        if(yCoord(pinShp1CenterPt) < yCoord(pinShp2CenterPt) then t
         else nil
         );if
       ("right"
         else nil
         );if
       (t
        error("unexpected data")
     );case
 );let
);procedure
I tried creating a list of the sorted pins using the following foreach mapcar function:
But I want to return each pin coordinate to the table using:
cv~>shape~>pin~>term~>pins~>fig~>bBox
But this would give me all the coordinates of a particular pin instead of what is  being sorted..
How can I specify which sorted pin coordinate to return to the table?
