  3. function to identify point locates within a polygon reg...
  • Views 16023
function to identify point locates within a polygon region
zhisong
zhisong over 14 years ago
Hi Expert,
Do you think SKILL have function to identify a point whether locates within a polygon region?
For example, I'm checking whether label~>xy locates inside prBoundary, because label text may expand out of prBoundary, so dbGetTrueOverlaps can't give the exact answer.
Does someone have exist code to check this? Or any tips?
-Jason
    Jason,
    You could use leIsPointInsideFig(figId label~>xy) for this.
  • zhisong
     I can find this function in IC6.1, but for IC5.1 do you have any idea?
    -Jason
    Jason,
    You could use the function CCSpointInPolygon() which is in the code attached to my Solution 11024326 .
  • zhisong
    Andrew,
     Sorry for the late reply. And many thanks for your guidance.
    But I happen to find another procedure in IC51, absIsPointInsideFig. I'm not sure whether it belongs to Abstract function and check XL license or not, but anyway, it can check the location indeed.
    Best Regards
    -Jason
    Jason,
    OK, but be warned, that function no longer exists in IC61X. It is from a tool that is no longer supported (has been replaced by something else) in IC61.
