  3. How to change the width of a path using skill
  • Subscribers 150
  • Views 17431
SS007
SS007 over 14 years ago
How to change the width of a path using skill code.
I tried to chage the width of a selected Metal path using skill, but it is showing an *Error* message..
path=geGetSelSet()
(db:0x5c22b79b)
path~>width
(0.06)
 path~>width=list(0.1)
*Error* dbSetq: Invalid path width - (0.1)
 Regards
SS
  • SS007
    I've solved this by assigning directly.
    eg:  path~>width=0.1
    SS
    The reason why this is the case is because geGetSelSet() is returning a list of path objects. If you do list_of_dbIds~>width it will return a list of the width attribute values for each member of the list of dbIds - it corresponds to doing foreach(mapcar dbId list_of_dbIds dbId~>width).
    When you assign using ~>, a similar thing happens, it will iterate over the dbIds and set the width attribute on each, so:
    list_of_dbIds~>width=0.1 is effectively like doing foreach(dbId list_of_dbIds dbId~>width=0.1) (actually it's a mapcar again, because it will return the result of the assignment, but that's a detail I won't bore you with. If instead you had a list of widths:
    widthList=list(0.1 0.2)
    and had two things selected, and you wanted to set them in turn, you could do:
    foreach((dbId width) list_of_dbIds widthList dbId~>width=width)
    Hope that makes it clearer.
  • SS007
    Thank you Andrew
    You gave me a clear picutre about it
    Regards
    Nisanth.SS
