  3. Sorting the list of coordinates of a polygon
  • Subscribers 150
  • Views 16049
SS007
SS007 over 14 years ago
I need to sort the list of coordinates of a polygon, first by their X coordinates and then by their Y coordinates. This will order the points, from top to bottom and left to right.
I tried using ciXYSortInsts() to sort the coordinate list as shown below. But the output is same as the input..
Am I using ciXYSortInsts() correctly, If not please tell me some other way to sort this list.
item=geGetSelSet()
(db:0x5c22c11e)
item~>xy
item~>xy
(nil)
y=item~>points
(((1.586 1.035)
 (1.586 0.795)
 (1.53 0.795)
 (1.53 0.91)
 (1.345 0.91)
 (1.345 0.795)
 (1.214 0.795)
 (1.214 1.035)
ciXYSortInsts(y)
(((1.586 1.035)
 (1.586 0.795)
 (1.53 0.795)
 (1.53 0.91)
 (1.345 0.91)
 (1.345 0.795)
 (1.214 0.795)
 (1.214 1.035)
Regards
SS
    That clearly won't work, because ciXYSortInsts is expecting you to provide a list of instance ids. You've not done that - you've given it a list of a list of coordinates. So it's doubly wrong - you have a list of lists, and each member is a coordinate not an instance id.
    I can't quite work out why you'd want to do this, but it's easy enough to write:
    procedure(MYxyLessp(a b)
      cond(
        (xCoord(a)<xCoord(b) t)
        (xCoord(a)>xCoord(b) nil)
        (yCoord(a)<yCoord(b) t)
        (t nil)
    y=car(geGetSelSet())~>points
    y=sort(y 'MYxyLessp)
    Be aware that sort is a destructive function and so you must use the return value rather than just assuming that the list is modified in place.
