  3. Equivalent function of techFindViaDefByName in IC5
  • Views 15264
cessej
cessej over 14 years ago
Anyone who has the equivalent function of techFindViaDefByName in IC5?
Thank you.
    There's not really a direct equivalent since there's no such thing as a viaDef in IC5141, but there's  leGetContactNameArray() to find the "contact" devices defined in the tech file, and you can give the name of one of these to leCreateContact(). Vias are just instances in IC5141, so they don't particularly need any special API.
  • cessej
    Thanks for the reply. It helps to shorten my code.
    Initially I'm using these lines to get via information, now I can use the leGetContactNameArray() replacing techGetDeviceInClass.
    foreach(mapcar device techGetDeviceInClass(techGetTechFile(geGetEditCellView()) "syContact" "symbolic") techGetDeviceCParam(techGetTechFile(geGetEditCellView()) device "symbolic"))
    foreach(mapcar device techGetDeviceInClass(techGetTechFile(geGetEditCellView()) "cdsVia" "layout") techGetDeviceCParam(techGetTechFile(geGetEditCellView()) device "layout"))
