  3. what is the syntax for xmodmap command ?
  • Subscribers 150
  • Views 15013
GiriBabu
GiriBabu over 14 years ago
 hi all,
I saw a script in cadence doccuments which is used to set bindkeys for number keys in num lock keypad.  When iam exicuting that in my icfb then it shows error. Script is in below. What's the problem in it?
xmodmap -e "add Mod3 =KP_0 KP_1 KP_2 KP_3 KP_4 KP_5 KP_6 KP_7 KP_8 KP_9"
(*Error* eval: undefined function - xmodmap)
xmodmap -pm
;mod3        KP_0 (0x5a),  KP_1 (0x57),  KP_2 (0x58),  KP_3 (0x59),  KP_4 (0x53),  KP_5 ;(0x54),  KP_6 (0x55),  KP_7 (0x4f),  KP_8 (0x50),  KP_9 (0x51)
;Then set the DFII bindkeys as:
hiSetBindKey( "Command Interpreter" "Shift<Key>KP_1" "printf( \"hello1\")")
;the above setting is for NumLock: ON
hiSetBindKey( "Command Interpreter" "<Key>KP_1" "printf( \"helloEnd\")")
;the above setting is for NumLock: OFF
hiSetBindKey( "Command Interpreter" "Shift<Key>KP_8" "printf( \"hello8\")")
hiSetBindKey( "Command Interpreter" "<Key>KP_8" "printf( \"helloUp\")")
;If the xmodmap output is like below, you would need to set the bindkeys a bit differently:
;$ xmodmap -pm
;mod3        KP_Insert (0x5a),  KP_End (0x57),  KP_Down (0x58),  KP_Next (0x59),  KP_Left (0x53),  KP_Begin (0x54),  KP_Right (0x55),  KP_Home (0x4f),  KP_Up (0x50),  KP_Prior (0x51)
hiSetBindKey( "Command Interpreter" "Shift<Key>KP_End" "printf( \"hello1\")")
hiSetBindKey( "Command Interpreter" "<Key>KP_End" "printf( \"helloEnd\")")
hiSetBindKey( "Command Interpreter" "Shift<Key>KP_Up" "printf( \"hello8\")")
hiSetBindKey( "Command Interpreter" "<Key>KP_Up" "printf( \"helloUp\")")
Thank you,
venu
    Not entirely sure what you're trying to achieve here, but xmodmap is a UNIX command, not something to type in the CIW. See "man xmodmap" for more details.
