  3. selecting at particular location
  • Replies 14
  • Views 19789
Rojalin
Rojalin over 14 years ago
Hii,
 Can anybody say how to select objects at a particular coordinates??
  • Quek
    Quek over 14 years ago
    Hi Rojalin
    Please use geSelectPoint. You can refer to $CDSHOME/doc/skdfref/skdfref.pdf for more details.
    Best regards
    Quek
  • Rojalin
    hi,
       thanks Quek.
    I want to put via at the point where my cursor is.
    So  when i give this command geSelectPoint(hiGetCommandPoint() It is showing error like
       hiGetWStruct:arg must be wtype.
     So can you please say how to resolve this.
  • Quek
    Hi Rojalin
    Please use geSelectPoint(hiGetCurrentWindow() hiGetCommandPoint()). Please refer to $CDSHOME/doc/skdfref/skdfref.pdf for more details on the cmd syntax.
    Best regards
    Quek
  • Rojalin
      I got the point of location where i need to put via by points object from the metal layer.But i am unable to put via there by using dbcreatevia() syntax.
    Can anybody say how to put via there??Is there any other option??
    Rojalin
    Why can't you use dbCreateVia?
  • Rojalin
    hi,
      In dbCreatevia one parameter via_defid is there.How to get that parameter?
    Rojalin
    Rojalin,
    Use techFindViaDefByName()
  • Rojalin
    hi.
       By using that function it is showing like undefined function.
    What version are you using? You didn't say...
    The dbCreateVia and techFindViaDefByName functions only exist in IC61X.
  • Rojalin
    I am using IC5 version.
