  3. Help on creating a Bus.
  • Replies 7
  • Views 18634
venuuuuu
venuuuuu over 14 years ago
hi guys,
I have a code that creats  Bus(group of methals) in my layout. When i call it then it shows widow box & It has options width(for metal width), number(for no. of metals), layer( for layer selection), snap mode. Now problem is number of metals doesnot get what i entered in that window box. Code is below.
 procedure(bus()
  let( (form)
 if(boundp('CCSmetBusForm) && CCSmetBusForm then
      form = CCSmetBusForm
    else
      form = CCScreateMetBusForm()
    ); if
    when(hiIsForm(form)
      enterPath(
        ?prompts        list("Enter points for Metal Bus path")
        ?form           form
        ?points         nil
        ?doneProc       "CCSmetBusDoneProc"
        ?addPointProc   "CCSmetBusPoints"
        ?delPointProc   "CCSmetBusPoints"
        ?pathWidth      form->width->value
       ;?acceptString  form->number->value
        ?alwaysMap      t
        ?cmdName        "CCSmetBus"
      ); enterPath
    ); when the form exists
  ); let
); procedure CCSmetBus
procedure(CCScreateMetBusForm()
  let( (width number layer snap snapModes form cv techId)
    if(cv = geGetEditCellView(hiGetCurrentWindow()) then
      if(techId = techGetTechFile(cv) then
 width = hiCreateFloatField(
          ?name 'width
          ?prompt "Width"
          ?value 1.0
          ?range list(0.3 2.0)
          ?callback "CCSchangeMetBusWidth()"
          ); hiCreateFloatField
 number = hiCreateFloatField(
            ?name 'number
   ?prompt "Number"
            ?value 1.0
            ?range list(1.0 100.0)
            ?callback "CCSchangeMetBusNumber()"
snapModes = list("orthogonal" "L90XFirst" "L90YFirst")
        snap = hiCreateCyclicField(
          ?name 'snap
          ?choices      snapModes
          ?prompt       "Snap mode"
          ?value        car(member(envGetVal("layout" "snapMode")
                          snapModes)) || "orthogonal"
          ?callback     "CCSchangeMetBusSnap()"
        ); hiCreateCyclicField
layer = hiCreateLayerCyclicField(
          techId
          "Layer"
          leGetValidLayerList(techId) || list(leGetEntryLayer(techId))
          'layer
        ); hiCreateLayerCyclicField
 form = hiCreateAppForm(
          ?name 'CCSmetBusForm
          ?formTitle "Metal Bus"
          ?formType     'options
          ?buttonLayout 'HideCancelDef
          ?fields list( list(width 0:0 100:30 50)
            list(snap 120:0 100:30 70)
            list(number 0:30 200:30 50)
           list(layer 0:90 200:30 50))
        ); hiCreateAppForm
 leSetFormSnapMode(form->snap->value)
        CCSshieldMetalForm = form
      else
        error("Could not obtain technology information")
      ); if the technology information can be obtained
    else
    else
      error("Shield metal functions require a cellview to be current")
    ); if a current cellview exists
  ); let
); procedure CCScreateMetBusForm
procedure(CCSchangeMetBusWidth()
  let( (origWidth)
    when(boundp('CCSmetBusForm) && CCSmetBusForm
      origWidth = CCSmetBusForm->width->value
      CCSmetBusForm->width->value = origWidth
      unless(CCSmetBusForm->currentWidth == CCSmetBusForm->width->value
        CCSmetBusForm->currentWidth = CCSmetBusForm->width->value
      ); unless
      changeEnterFun(
        'enterPath
        ?pathWidth      CCSmetBusForm->width->value
        ;?acceptString     CCSmetBusForm->number->value
        ?points         CCSmetBusForm->points
        ?form           CCSmetBusForm
      ); changeEnterFun
  ); let
); procedure CCSchangeMetBusWidth
procedure(CCSchangeMetBusNumber()
  let( (defaultNumber)
      defaultNumber= CCSmetBusForm->number->value
      CCSmetBusForm->number->value = defaultNumber
      unless(CCSmetBusForm->currentNumber == CCSmetBusForm->number->value
        CCSmetBusForm->currentNumber = CCSmetBusForm->number->value
   ); unless
      changeEnterFun(
        'enterPath
        ?form           CCSmetBusForm
      ); changeEnterFun
  ); let
); procedure CCSchangeMetBusNumber
procedure(CCSchangeMetBusSnap()
    CCSmetBusForm->origSnap =
      leSetFormSnapMode(CCSmetBusForm->snap->value)
); procedure CCSchangeMetBusSnap
procedure(CCSmetBusPoints(win points "wl")
  when(windowp(win)
    ;; keep track of the points for when the enterFunction is changed
    CCSmetBusForm->points = points
); procedure CCSmetBusPoints
procedure(CCSmetBusDoneProc(win done points "wgl")
  let( ( form )
      if(done then
        ;; reset the currentWidth variable stored on the form
        ;; and reset the points list stored on the form
        form->currentWidth = nil
       form->currentNumber = nil
        form->points = nil
        CCSmetBusCB(
          win->cellView
          form->width->value
;          form->number->value
          CCSgetLPPfromLayerCyclic(form->layer->value)
          points
      else
        ;; put back the most recent previous snap mode
        when(CCSmetBusForm->origSnap
          leSetFormSnapMode(CCSmetBusForm->origSnap)
        ); when
      ); if done
    ); when form exists
  ); let
); procedure CCSmetBusDoneProc
procedure(CCSmetBusCB(cv width  layer points  "dfll")
if( (width >=  techGetSpacingRule(techGetTechFile(cv) "minWidth" layer)) then
layerWidth = width
);if
layerSpace = techGetSpacingRule(techGetTechFile(cv) "minSpacing" layer)
let((a b n)
b = list()
a = list()
n = number
for(i 0 n-2
a= list(
                            ?layer      layer
                            ?justification "left"
                            ?width layerWidth
                            ?sep  ( layerSpace * (i+1)) + ( layerWidth * i)
                            ?choppable  t
b = cons(a b)
);for
b = reverse(b)
rodCreatePath(
      ?cvId             cv
      ?layer            layer
      ?width            layerWidth
      ?pts              points
      ?justification "center"
      ?choppable  t
      ?offsetSubPath    b
   ); rodCreatePath
  );let
); procedure CCSmetBusCB
procedure(CCSgetLPPfromLayerCyclic(layCyc "l")
  parseString(
    buildString(
      parseString(cadddr(layCyc) "()")
;and then i add it as menu item.
procedure(AmitAddMenu(_args)
  let( (item1 item2 item3)
    ;; create a couple of menu items
    item1 = hiCreateMenuItem( ?name 'item1 ?itemText "labels"
              ?callback "labels()"
            );labels() is a procedure which ididn't shown here
    item2 = hiCreateMenuItem( ?name 'item2 ?itemText "Bus"
              ?callback "bus()"
       item2 = hiCreateMenuItem( ?name 'item3 ?itemText "Setlsw"
              ?callback "venu()"
            )venu() is a procedure which i did not shown here
    ;; create a menu that includes the menu items and return a list of the
    ;; pulldown menus
    list(hiCreatePulldownMenu('AmitMenu "FPS" list(item1 item2 item3)))
  );let
); procedure
;; create a userMenuTrigger trigger that automatically adds the menu
deRegUserTriggers("maskLayout" nil 'AmitAddMenu)
please help me to do it
    This had numerous basic SKILL errors, which I'm very surprised you were unable to find. Things like parentheses which weren't matched,  arguments not being passed into functions, and so on. I've corrected various things and put a comment with "AB" in to indicate what I changed.
     procedure(bus()
      let( (form)
        else
        ); if
        when(hiIsForm(form)
          enterPath(
            ?form           form
            ?points         nil
            ?alwaysMap      t
          ); enterPath
      ); let
              ?name 'width
              ?prompt "Width"
              ?value 1.0
     ; AB - changed this to be an integer only field so that
     ; it can't be a fractional number of wires!
     number = hiCreateIntField(
                ?name 'number
       ?prompt "Number"
                ?value 1
                ?range list(1 100)
              ?name 'snap
              ?choices      snapModes
              ?prompt       "Snap mode"
              techId
              "Layer"
              'layer
              ?formType     'options
            ); hiCreateAppForm
          else
        else
      ); let
      let( (origWidth)
          ); unless
          changeEnterFun(
            'enterPath
            ?form           CCSmetBusForm
          ); changeEnterFun
      ); let
       ); unless
          changeEnterFun(
            'enterPath
            ?form           CCSmetBusForm
          ); changeEnterFun
      ); let
      when(windowp(win)
      let( ( form )
          if(done then
            form->points = nil
            CCSmetBusCB(
              win->cellView
              form->width->value
          ; AB - this was commented out for some reason - needs to pass the number in
              form->number->value
              points
          else
            ); when
          ); if done
        ); when form exists
      ); let
    procedure(CCSmetBusCB(cv width number layer points  "dfxll")
    layerWidth = width
    );if
    let((a b n)
    b = list()
    a = list()
    ; AB - this was just trying to get a global variable from somewhere?
    ; so I added number to the argument list of the function
    n = number
    for(i 0 n-2
    a= list(
                                ?layer      layer
                                ?width layerWidth
                                ?choppable  t
    b = cons(a b)
    );for
    b = reverse(b)
    rodCreatePath(
          ?cvId             cv
          ?layer            layer
          ?width            layerWidth
          ?pts              points
          ?choppable  t
          ?offsetSubPath    b
       ); rodCreatePath
      );let
      parseString(
        buildString(
                  ?callback "bus()"
           ; AB - this was item2 in the code as posted on the forum.
           ; so was obscuring the item2 above.
           item3 = hiCreateMenuItem( ?name 'item3 ?itemText "Setlsw"
                  ?callback "venu()"
                ) ;venu() is a procedure which i did not shown here
        ;; pulldown menus
      );let
    ); procedure
  • venuuuuu
    Thank you  for reply. Now i need to attach space(spacing between metals) option to the form. For that i write float field and add this  to the form. I done small changes in code. But CIW shows error's. My code is below
     procedure(bus()
      let( (form)
        else
        ); if
        when(hiIsForm(form)
          enterPath(
            ?form           form
            ?points         nil
            ?alwaysMap      t
          ); enterPath
      ); let
      let( (width space number layer snap snapModes form cv techId)
              ?name 'width
              ?prompt "Width"
              ?value 1.0
              techId
              "Layer"
              'layer
      space = hiCreateFloatField(
              ?name 'space
              ?prompt "Space"
              ?value .3;techGetSpacingRule(techGetTechFile(cv) "minSpacing" layer)
              ?range list(0.2 5.0)
              ?callback "CCSchangeMetBusSpace()"
                ?name 'number
       ?prompt "Number"
                ?value 1
                ?range list(1 100)
              ?name 'snap
              ?choices      snapModes
              ?prompt       "Snap mode"
              ?formType     'options
                list(number  0:30 100:30 50)
                list(space 0:60 200:30 50)
            ); hiCreateAppForm
          else
        else
      ); let
      let( (origWidth)
          ); unless
          changeEnterFun(
            'enterPath
            ?form           CCSmetBusForm
          ); changeEnterFun
      ); let
    procedure(CCSchangeMetBusSpace()
      let( (origSpace)
          origSpace = CCSmetBusForm->space ->value
          CCSmetBusForm->space ->value = origSpace
          unless(CCSmetBusForm->currentSpace == CCSmetBusForm->space->value
            CCSmetBusForm->currentSpace = CCSmetBusForm->space->value
          ); unless
          changeEnterFun(
            'enterPath
            ?form           CCSmetBusForm
          ); changeEnterFun
      ); let
       ); unless
          changeEnterFun(
            'enterPath
            ?form           CCSmetBusForm
          ); changeEnterFun
      ); let
      when(windowp(win)
      let( ( form )
          if(done then
            form->points = nil
            CCSmetBusCB(
              win->cellView
              form->width->value
              form->space->value
              form->number->value
              points
          else
            ); when
          ); if done
        ); when form exists
      ); let
    procedure(CCSmetBusCB(cv width number space layer points  "dfxll")
    layerWidth = width
    );if
    layerSpace = space ;techGetSpacingRule(techGetTechFile(cv) "minSpacing" layer)
    let((a b n)
    b = list()
    a = list()
    n = number
    for(i 0 n-2
    a= list(
                                ?layer      layer
                                ?width layerWidth
                                ?choppable  t
    b = cons(a b)
    );for
    b = reverse(b)
    rodCreatePath(
          ?cvId             cv
          ?layer            layer
          ?width            layerWidth
          ?pts              points
          ?choppable  t
          ?offsetSubPath    b
       ); rodCreatePath
      );let
      parseString(
        buildString(
    when i exicutes this then CIW(5141) shows following error:
     *Error* CCSmetBusCB: argument #3 should be an integer (type template = "dfxll") - 0.3
     *Error* load: error while loading file - "*loadstring*"
  • venuuuuu
     hi Andrew,
    Thank you very much. I done it with all your  help.
  • nandapatilhire
    nandapatilhire over 14 years ago
    The buses created will not be able to stretch/select individually...
    This can be solved by Edit->Other->Convert to Polygon in Layout Editor window.
    Nanda.
  • Mona Xu
    Mona Xu over 10 years ago
    hi   venuuuuu,
        I want to attach space option to the form,too.And the errors is the same as yours. Do you know how to correct the errors?
    Mona
    A better solution would be to use Create->Wiring->Bus in Virtuoso Layout Suite XL. That's far more advanced.
  • Mona Xu
    Hi Andrew ,
    Thank you for your reply.
    It doesn't work in IC5141. And I just found the error,I changed "dfxll" to "dffxll",and it works.
    Mona
