  3. customVias and rodHandles in 6.1.5
  • Views 14807
dmay
dmay over 14 years ago
We have a MOS pcell that places a symbolic contact in 5.1.41. In the contact are some rod objects and handles that we then access in the MOS code. The code looks something like this:
symb1DBid = dbCreateParamInst(…..)
firstConRod = rodGetObj(strcat(symb1DBid~>name "/firstContact") cv)
when(firstConRod
         origLLpoint = rodGetHandle(firstConRod "cutLayVLL")
This still works in 6.1.5, but we're thinking we should use dbCreateVia instead of dbCreateParamInst. The problem with this is that the resulting customViaDef doesn't have an instance name. How would we go about retrieving the rodHandle from the lower level shape if we are unable to provide it a hierarchical name (symb1DBid~>name is nil).
I tried assigning a rod name to the customVia object and then used that name, but I get the following error when rodGetObj is used:
r=rodNameObject(?shapeId symbTmpDBid)
firstConRodUpper = rodGetObj(strcat(r~>name "/firstContact") cv)
*WARNING* rodGetObjByName: "via0" in hierarchical name "via0/firstContact" is not the name of an instance
In summary, I have two questions:
1. Should we use dbCreateVia instead of dbCreateParamInst?
2. If we use dbCreateVia, how do we access a hierarchical rod object in a customVia?
Derek
    Derek,
    I see you've filed a service request on this. I think it's going to need attention from R&D, as I'm not aware of a way around this right now. I think rodGetObj will need enhancing to handle hierarchical handle names where vias are involved.
