  3. convert "<>" into "[]" in pin names
  • Views 2562
GiriBabu
GiriBabu over 14 years ago
 hi all,
I need to change the pin's name to the "[]" instead of "<>". For example, trim<3> into trim [3]. So please help me to do this
Thank you
venu
  • Eduard Raines
    Eduard Raines over 14 years ago
    Hi Venu,
    Are you talking about schematic or layout?
    If it's layout ,how did you get layout pin names with "<>"?Did you import P&R gds  file?
    What version of Cadence are you using?
    Eduard Raines
  • venuuuuu
    venuuuuu over 14 years ago
     hi,
    Sorry for less  information. Iam talking about layout. We have top level layout that has pinNames ending with "[" like thi[1], vb[2],fg[3],..... I need to convert it into thi<1>,vb<2>,fg<3>....
    Iam using the version 5.1.4.1
    Thank you,
    venu
  • venuuuuu
     hi all,
    I have a code  belongs to this topic. But it doesn't work properly. It convert Vreg[32], Vreg[31] into Vreg<32>, Vreg<32> . Can u verify it?
     ; *Title:        How to change Pin labels from "<>" to "["
    ; Name: CCSchangeLabelDelimiter.il
    ; Save this code to a file such as CCSchangeLabelDelimiter.il
    ; and then load in CIW as
    ; load("CCSchangeLabelDelimiter.il").
    ; Then type CCSchangeLabelDelimiter() in CIW.
    procedure(CCSchangeLabelDelimiter()
     let( (cv mylabels myUniquelabels tmpcv labelText name
          index newlab)
          ;;cv = geGetEditCellView()
          cv = dbOpenCellViewByType("venu" "mic2850_dig"
          "layout1" nil "a")
          ;;search the cell hierarchy for labels that start
         ; with "A" and end with ">"
          ;;The third argument defines the number of hierarchy
           ;  levels you wish to search
             mylabels=leSearchHierarchy( cv cv~>bBox 32
             "label"
             list( list( "text" "==" "" ) list("text"
          ;;create a list of unique labels
             myUniquelabels = nil
             foreach(x mylabels
             unless(member(x myUniquelabels)
             myUniquelabels = cons(x
             myUniquelabels)
             foreach(lab myUniquelabels
             labelText =
             lab~>theLabel
             name =
             car(parseString(labelText
             index=
             car(parseString(cadr(parseString(labelText
             newlab=
             buildString(list(buildString(list(name
             index ) "<") ">") "")
             printf("Original Label was %s\n"
             labelText)
             printf("The new Label would be
             %s\n" newlab)
             ;;if label is not in top level, we need to
             ;open the instance master in edit
             ;;mode to modify the label
             if(lab~>cellView~>cellName !=
             cv~>cellName then
             tmpcv =
             dbOpenCellViewByType(lab~>cellView~>libName
             lab~>cellView~>viewName
             nil "a")
             ;;println(lab~>name)
             lab~>theLabel = newlab
             dbSave(tmpcv)
             dbClose(tmpcv)
             ;; for top level labels
             dbSave(cv)
             dbClose(cv)
             );let
             );procedure
    hiSetBindKey("Layout" "Ctrl<Key>5"     "CCSchangeLabelDelimiter()")
    ; Load in the Virtuoso CIW using load("CCSchangeLabelDelimiter.il")
    ; Then type CCSchangeLabelDelimiter() in the CIW.
    ;; End of CCSchangeLabelDelimiter.il
     If it works that enough to my expertetions.
  • GiriBabu
    hi all,
    I found above code in cadence library. The actual code is below.  It converts label "Aenu<23>" into "Aenu<23>[23]". But i need to convert label  "Aenu<23>" into "Aenu[23]".
    ;*Title:       ; How to change Pin labels from "<>" to "["
          index newlab)
          cv = dbOpenCellViewByType("venu" "practice"
          "layout" nil "a")
          ;with "A" and end with ">"
             ;levels you wish to search
             "label"
             list( list( "text" "==" "^A" ) list("text"
             foreach(x mylabels
             myUniquelabels)
             labelText =
             lab~>theLabel
             name =
             index=
             newlab=
             index ) "[") "]") "")
             labelText)
             %s\n" newlab)
             cv~>cellName then
             tmpcv =
             nil "a")
             dbSave(tmpcv)
             dbClose(tmpcv)
             dbSave(cv)
             dbClose(cv)
             );let
             );procedure
  • venuuuuu
     hi guys.
    I done this script. It works good. Thank you very much.
