  3. create pins on power rails from labels
  • Subscribers 150
  • Views 16033
ronnyf
ronnyf over 14 years ago
I have layouts of IO cells which only include labels on all power rails. Now I would like to create pins from the labels, but the pins should be stretched to the heigth of the underlying power rail.
It is "easy" to put a normal pin on the label, but what about the stretching of the pin? Does anyone have a snippet of code for this or a suggestion of Skill functions to work with? I think that it is dangerous just to get the lower and upper coordinates of the underlying metal shapes because the metal shapes could be separated or something like this.
 Thank you very much for some ideas,
Ronny
  • Eduard Raines
    Eduard Raines over 14 years ago
    Hi Ronny,
    What about power rails size?Do they all have same width or they all diffrent?
    What is the object type of your IO power rails: path,pathSegs,polygon,rectangle...?
    What is the distance between your IO cells ?
    Eduard Raines
  • ronnyf
     Hi Eduard,
    first of all, the problem is that I want to run the Skill routine over all IO cells from a library. Thatswhy I can't have a look at all special cases but I hope I got all requirements now:
    - The power rails have different heights (inside an IO cell) and the IO cells have different sizes too.
    - Most of the objects are rectangles, but there are also polygons (like L-shapes), both covered with a lot of metal flecks.
    - What do you mean with the distance between IO cells? Finally in the toplevel layout they are joined to an complete IO ring.
    Thank you,
    Ronny
  • ronnyf
    Hi all,
    does anyone know if there exist a Skill function which measures the distance from a given point to the right, left, bottom or top border of the underlying shape?
    Thank you veru much,
    Ronny
