  3. Help on getting Library names for all instances on display...
  • Replies 12
  • Views 23992
Help on getting Library names for all instances on display form
venuuuuu
venuuuuu over 14 years ago
 Hi guys,
 I tried some code to  get  Library names for all instances on display form. I get it  But Display form doesnot work properly .
 Error is shown below
 *Error* TrShapeReportToPort: too few arguments (2 expected, 1 given) - (db:246261804)
 cv = geGetEditCellView()
procedure( TrShapeReportToPort( cv outport )
cv = geGetWindowCellView( cv )
;cv = geGetEditCellView()
librarys=nil
fprintf(
outport
"%s %s %s contains library's:"
cv~>libName cv~>cellName cv~>viewName
foreach(libryname cv~>instances~>libName
foreach(singlelib librarys
if(singlelib!=libryname then
librarys=cons(libryname librarys)
foreach(libname librarys
fprintf( outport "\n%-10s %-10s" "Library" libname )
list( cv~>libName cv~>cellName cv~>viewName )
TrReportBBox = '((120 729) (372 876))
procedure( TrShapeReport( cv )
thePort = outfile( "/tmp/ShapeReport.txt" )
when( thePort
TrShapeReportToPort( cv thePort )
close( thePort )
) ; when
view( "/tmp/ShapeReport.txt" TrReportBBox "Librarys" )
) ; procedure
hiSetBindKey("Layout" "Ctrl<Key>1"      "TrShapeReportToPort(cv)")
    Isn't that error message pretty self-explanatory? It's saying you're calling the function TrShapeReportToPort() with one argument, and it's expecting two. Looking at the definition of your code, it has two arguments, but when called from the bindkey, it is only giving a single argument.
    Hardly surprising it fails.
    I've not checked the rest of the code, because the formatting makes it pretty hard to read. Not really sure what it's trying to do - it seems pretty unclear. There's no form involved, so when you're talking about "getting library names for all instances on display form", I don't know what you mean - but the code won't be doing that. It appears to be doing some odd things...
  • venuuuuu
     hi Andrew,
     I wrote the TrlibraryReport function. It creates a list of librarys that cellview instances contains. But it dosn't working properly.
    librarys=nil
    In above code, librarys(variable) should contain list of library's in in cellview. But when i enter library's in CIW then it shows "nil". Can u identify what's the problem?
     If it works  then librarys function displays a list of library's in the CIW. And then this function to send the report to a temporary file and to display this file for the user in a Design Framework II text window. Now total code is shown below.
    procedure( TrlibraryReportToPort( cv outport )
    librarys=nil
    fprintf(
    outport
    procedure( TrlibraryReport( cv )
    thePort = outfile( "/tmp/libraryReport.txt" )
    when( thePort
    TrlibraryReportToPort( cv thePort )
    close( thePort )
    ) ; when
    view( "/tmp/libraryReport.txt" TrReportBBox "Librarys" )
    ) ; procedure
     Or is there anyway to display librarys in a display?
  • venuuuuu
     hi Andrew,
    I modified above code. It works fine but problem is all library list contains repeated libraryname's. The code is  below
    ;cv = geGetWindowCellView( cv )
    librarys=nil
    librarys1=list(car(cv~>instances~>libName))
    librarys=append(librarys1 librarys)
    fprintf(
    outport
    ;;to doesnot get repeated libraryname's in list
    if(singlelib != libryname then
    librarys=append(list(libryname) librarys)
    );if
    );foreach
    );foreach
    fprintf( outport "\n%-10s "  libname )
    when( thePort
    close( thePort )
    ) ; when
    ) ; procedure
    hiSetBindKey("Layout" "Ctrl<Key>1"      "TrlibraryReport(cv)")
    Then o/p file displays
     venu practice layout contains library's:
     rajesh
     rajesh
     rajesh
     rajesh
     venu
     venu
    In above 1830bd18ba I want to display like this:
     venu
    rajesh
    I wrote foreach , if functions  in above code that is not working properly. please help me.
  • dmay
    dmay over 14 years ago
    I recommend you build your library list using "cons" instead of "append" or "append1". This is the most efficient way to build a list if the order of the list doesn't matter. Then to make sure you don't have duplicates, add a simple member check. Do something like this:
    libList = nil
    foreach(lib cv~>instHeaders~>libName
        unless(member(lib libList
           libList = cons(lib libList)
    The instHeaders list will be much shorter than the instances list since it will only have each referenced cellView in the list once (unless it is a pcell).
    Derek
  • venuuuuu
     Thank you  Derek. I it works good. Nd thank you all. I done it with all your help.
  • GiriBabu
    GiriBabu over 14 years ago
     hi all,
    This code working only for present cellview level. But i need hierarchy level also. What iam talking about is when i run this script for top level, then my report shows list of library's of instances of top level block of top level view only. But i need list for hierarchy  Is there any command to get library names of instances which are in hierarchy level & present cellview.
    If you've been on the SKILL training class, there's an example of doing just this - getting the cellViews used throughout the hierarchy. In fact I'm sure there are numerous examples of doing a recursive hierarchy traversal both in the forum and on Cadence Online Support.
    One approach (from a 10 second search) might be to use code such as in this post.
    Are you posting as two different users?
  • venuuuuu
     hi Andrew,
     It works fine. But it shows the information that which my layout doesnot exist. For example
               ("venu" "BUC" "layout_fp1")
                 ("venu" "BUC" "layout")
                ("venu" "BUC" "schematic")
          But i used   ("venu" "BUC" "layout")  only in my layout.  So i need only ("venu" "BUC" "layout") . Iam trying to get just like tree function in layout.
    That was just one example.  Here's another I just threw together which does it more directly:
    procedure(CCFfindLibsUsed(@optional
        (cv geGetEditCellView()) libsFound
        (visited makeTable('visited nil)))
      foreach(master cv~>instanceMasters
        unless(visited[master]
          visited[master]=t
          unless(member(master~>libName libsFound)
            libsFound=cons(master~>libName libsFound)
          libsFound=CCFfindLibsUsed(master libsFound visited)
      libsFound
    You'd then call:
    CCFfindLibsUsed()
    or
    CCFfindLibsUsed(topCellViewId)
  • venuuuuu
     hi Andrew,
    I still not getting this code. My aim is to get library names for all instances used in cell view (It should get library names hierarchally). my code is below.
    procedure( TrlibraryReportToPort( cv  )
    libList = nil
    foreach(inst cv~>instHeaders
        lib=inst~>libName
        unless(member(lib libList)
    cellname=inst~>cellName
    viewname=inst~>viewName
    cv1 = dbOpenCellViewByType(lib cellname viewname nil "r")
    foreach(inst1 cv1~>instHeaders
       lib1=inst1~>libName
        unless(member(lib1 libList)
           libList = cons(lib1 libList)
    cellname1=inst1~>cellName
    viewname1=inst1~>viewName
    cv2 = dbOpenCellViewByType(lib1 cellname1 viewname1 nil "r")
    foreach(inst2 cv2~>instHeaders
       lib2=inst2~>libName
        unless(member(lib2 libList)
           libList = cons(lib2 libList)
    cellname2=inst2~>cellName
    viewname2=inst2~>viewName
    cv3 = dbOpenCellViewByType(lib2 cellname2 viewname2 nil "r")
    foreach(inst3 cv3~>instHeaders
       lib3=inst3~>libName
        unless(member(lib3 libList)
           libList = cons(lib3 libList)
    cellname3=inst3~>cellName
    viewname3=inst3~>viewName
    cv4 = dbOpenCellViewByType(lib3 cellname3 viewname3 nil "r")
    foreach(inst4 cv4~>instHeaders
       lib4=inst4~>libName
        unless(member(lib4 libList)
           libList = cons(lib4 libList)
    cellname4=inst~>cellName
    viewname4=inst~>viewName
    cv5 = dbOpenCellViewByType(lib4 cellname4 viewname4 nil "r")
    foreach(inst5 cv5~>instHeaders
       lib5=inst5~>libName
        unless(member(lib5 libList)
           libList = cons(lib5 libList)
    cellname5=inst~>cellName
    viewname5=inst~>viewName
    cv6 = dbOpenCellViewByType(lib5 cellname5 viewname5 nil "r")
    foreach(inst6 cv6~>instHeaders
       lib6=inst6~>libName
        unless(member(lib6 libList)
           libList = cons(lib6 libList)
     In this i wrote for 6 hierarchy levels only by for loop. For this i worte 6 for loops in top for loop. But I want simple way to
    get library list in hierarchally.
