  3. Get a list of variables in a given expression
  • Views 19199
cessej
cessej over 14 years ago
Anyone who have idea on how to get a list of variables in a given expression?
The expression is a string data type.
Thank you very much.
    What kind of expression is it? Is it an AEL expression (e.g. the kind of expression you have on a component parameter, which is referencing design variables as set in ADE) or a SKILL expression?
  • cessej
    Its a SKILL expression.
    Thanks.
    This code should work if the expression only contains lambda forms. If you use any syntax forms or macros, it may misinterpret symbols which are implicitly quoted as variables. For normal arithmetic expressions it will work fine though - it's only if you include things like ->,~> let, procedure, ' and so on that it will give the wrong result (it would add quite a bit of complexity to handle all of those).
    /* abVarsUsed.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 09, 2011
    Modified
    By
    Examples of usage:
    > abVarsUsed("1+2*(a+3*b)")
    (b a)
    > abVarsUsed("a+b+c+d*e+expt(f g)")
    (g f e d c b a)
    SCCS Info: @(#) abVarsUsed.il 12/09/11.09:10:28 1.1
    *              abVarsUsed(expression [varsUsed])               *
    * When called with an expression in a string or list, returns  *
    *  a list of the variable names used in the expression. Makes  *
    *    the assumption that all functions are lambda functions    *
    procedure(abVarsUsed(expression @optional varsUsed)
        case(type(expression)
            (string
                foreach(subExpr linereadstring(expression)
                    varsUsed=abVarsUsed(subExpr varsUsed)
            (list
                ; ignore the car of the list because that's the
                ; function name
                foreach(elem cdr(expression)
                    case(type(elem)
                        (symbol
                            unless(member(elem varsUsed)
                                varsUsed=cons(elem varsUsed)
                        (list
                            varsUsed=abVarsUsed(elem varsUsed)
            (t
                (error "abVarsUsed: expecting string or list: %L\n" expression)
        varsUsed
  • cessej
    Thank you Andrew for helping me.
    The linereadstring is my starting point. I will just change the linereadstring(expression) to flattenList(linereadstring(BLOCKED EXPRESSION. flattenList is a user-defined function, then after that I can make the conditional statements to filter-out the the ~>,->,let,procedure, etc.
    Flattening the list would be the wrong way to do this, because you lose all context. That's why a recursive function is used. To handle this you'd want to do something clever in the bit where the comment saying "ignore the car" is. Depending on the function, you'd recursively call with selective arguments. For example, with these functions:
    getSGq (~>)/getq/dbGetq (->): 1st arg (not 2nd)
    setSGq (~>)/putpropq/dbSetq(->): 1st and 2nd arg (not 3rd)
    setq (=): 2nd arg (not 1st)
    let/procedure/prog/ - rather more complex!
    Why are you doing this anyway? If you're trying to identify (say) global variables, this is something SKILL Lint will do for you - this has the rules about such syntax forms built in to allow it to identify variables.
  • cessej
    I doing this for sorting the the multiple lines of expression based on the usage/position of variables.
    So far I don't have any complicated variable naming in my application, so I solved my problem at this moment.
    Please see the snapshot of my code. I know this one still need some improvement as what you have said before to become fully functional.
    procedure(sgGetVar(expr)
      let((varList propName propNameAssoc propOn propOnAssoc (propL 0) (propLAssoc 0) (propCtr 0) (propCtrAssoc 0))
        foreach(x flattenList(linereadstring(expr))
          ;for obj~>prop, gets how many getSGq are there
          if(x=='getSGq then
            propOn=t
            propL=propL+1
          ;count only symbol but not a function when propOn==t.
          if(symbolp(x) && !fboundp(x) && propOn then
            unless(propName propName=x)
            propCtr=propCtr+1
          ; for obj->prop, gets how many getq are there
          if(x=='getq then
            propOnAssoc=t
            propLAssoc=propLAssoc+1
          ;count only symbol but not a function if propAssoc==t.
          if(symbolp(x) && !fboundp(x) && propOnAssoc then
            unless(propNameAssoc propNameAssoc=x)
            propCtrAssoc=propCtrAssoc+1
          ;; gets variable name if symbol but not function, and propOn=nil and propOnAssoc=nil
          if(symbolp(x) && !fboundp(x) && !propOn && !propOnAssoc varList=cons(symbolToString(x) varList))
          ;;; adding the object name (with prop) if getSGq's total==propL+1
          if(propCtr==propL+1 then
           varList=cons(symbolToString(propName) varList)
           propName=nil propOn=nil propL=0 propCtr=0
          ;adding the object name (with assoc) if getq's total== propLAssoc+1
          if(propCtrAssoc==propLAssoc+1 then
           varList=cons(symbolToString(propNameAssoc) varList)
           propNameAssoc=nil propOnAssoc=nil propLAssoc=0 propCtrAssoc=0
        varList
