  3. streaming out a gds in IC5
  • Replies 10
  • Subscribers 150
  • Views 19107
Adhil
Adhil over 14 years ago
Hi Guys
i am trying to run the code below
 procedure(ConfigurestreamOut()
a = pipoDisplay(transStreamOutForm)
if(hiInFormApply(transStreamOutForm) then
cid = ipcBeginProcess("cd cal_drc;run_drc; cd ..")
hiDisplayAppDBox(
 ?name 'myBox
 ?dboxBanner "Adhil's DRC"
 ?dboxText "DRC run is complete!"
 ?callback "printf(\"DRC run is complete!!\")"
 ?dialogType 1
 ?dialogStyle 'modeless
 ?buttonLayout 'YesNo
procedure(CCSmyMenu(args)
prog((One myMenu)
One = hiCreateMenuItem(
 ?name 'configure
 ?itemText "Stream and Run"
 ?callback "ConfigurestreamOut()"
myMenu = list(
 hiCreatePulldownMenu(
  'myPersonalMenu
  "Run DRC"
  list(One)))
return(myMenu)
if(!boundp('myPersonalMenu) then
;deRegUserTriggers("schematic" nil 'CCSmyMenu nil)
deRegUserTriggers("maskLayout" nil 'CCSmyMenu nil)
;deRegUserTriggers("maskLayoutXL" nil 'CCSmyMenu nil)
else
printf("the menu has already been loaded\n")
 i want the drc run executed by ipcBeginProcess to start after the streamout of the gds is fully completed. how can I ensure full streamout? is there a flag or something to indicate the completion of the process.
On the otherhand, how can i streamout a gds automatically in IC5. the previous posts contain codes that are meant for IC6.
 Adhil.
    You'd use ipcBeginProcess() to launch "pipo strmout templateFile" and then either wait for the results, or use an exit handler to then launch the DRC.
  • Adhil
    Hi!
    what do you mean by "pipo streamout template file", is it a comand?, can you run skill codes in ipcBeginProcess?
    furthermore, are there any commands to automatically streamout gds s in skill for IC5?
     thanks for replying, I am still learning.
    Adhil
    Hi Adhil,
    "pipo strmout templateFile" is a UNIX command (note that strmout doesn't have "ea" in it). The templateFile is the same file you get by saving the settings to a file from the File->Export->Stream form, and you can build a similar file yourself.
    You can invoke the command from SKILL by doing:
    ipcId=ipcBeginProcess("pipo strmout templateFile")
    ipcWait(ipcId)
    say.
  • Adhil
    hi!
    I tried the code that you provided. when i tested it out on my terminal, unix responded saying that "pipo" does not exist. i asked my cad engineer and he said that i need some config files.
     thanks in advance
    Adhil.
    Your UNIX path must be set incorrectly. If you're using IC5141, the "pipo" command is in the same directory as the "icfb" command:
     UNIX_2> which pipo
    /export/home/apps/IC5141_isr/tools/dfII/bin/pipo
    UNIX_3> which icfb
    /export/home/apps/IC5141_isr/tools/dfII/bin/icfb
    UNIX_4> echo $path
    /export/home/apps/MMSIM101_isr/tools/bin /export/home/apps/IC5141_isr/tools/dfII/bin /export/home/apps/IC5141_isr/tools/bin /usr/local/bin /bin /usr/bin . /usr/X11R6/bin
    Maybe  you're launching icfb via a wrapper script which sets up the path. However, you should definitely be able to call pipo from ipcBeginProcess because the path must be set up either File->Export->Stream wouldn't work.
    Or you're using IC615, in which case the command is "strmout":
    UNIX_7> which strmout
    /export/home/apps/IC615_isr/tools/dfII/bin/strmout
    UNIX_8> echo $path
    /export/home/apps/MMSIM101_isr/tools/bin /export/home/apps/IC615_isr/tools/dfII/bin /export/home/apps/IC615_isr/tools/bin /usr/local/bin /bin /usr/bin . /usr/X11R6/bin
  • Adhil
    Hi Andrew!
    Thanks alot, its working now. When  i was running the ipc command on my CIW, the CIW did not reflect the status of the command execution, so i had to try it out on my terminal. but the strmout did not work at the begining so I setdt to IC5.latest, then it worked.
    On the otherhand, you did not say how i can setup the templateFile before i ran pipo strmout.
    Adhil.
    Hi Adhil,
    Actually I did say. If you bring up the File->Export->Stream form, fill it in and then save a template from this form, that's the contents you need.
    You'd have to write your own code to build the template if you're writing your own interface, but that's not difficult.
  • Adhil
    sorry i mean using code to setup the templateFile. the previous posts in this forum have codes for IC6 not IC5,
    Cadence Online Support Solution 11001322 shows how to do this.
  • Adhil
    Hi Andrew!
    My code is working now. i built a GUI to streamout and run drc. i now want to integrate a small terminal onto my gui so that i could view the streamout and subsequently the drc runs as they are processed on unix.
    Adhil.
