  3. How to create an graphic editable window?
  • Subscribers 152
  • Views 18859
Renee
Renee over 14 years ago
 I would like to create a graphic window with a dockable form by programming like below:
win1 = hiCreateWindow('default "graphics" "zl_win" "" t)
ses1 = hiCreateWindow('default "session" "zl_ses" "" t)
dock1 = hiCreateDockWindow(?appType "zl_dock1" ?widgetType "form" ?form hiCreateAppForm(?name 'TheForm1 ?formTitle "Test" ?fields list(list(layer_id 20:0 220:30 160))))
hiDockWindow(?window dock1 ?session ses1)
hiDisplayWindow(win1 ses1)
After the window is created, I would like to draw layout within it, however, it says that:
*WARNING* No application registered for prefix zl_win
Then I write: hiRegisterBindKeyPrefix("zl_win" "graphics"). After that, I tried to use the command:
dbCreateRect(geGetEditRep(window(10)) list((0 0) (10 10)) list("met1" "drawing"))
to draw a rect. It failed and said that:
*WARNING* (GE-2067): geGetEditCellView: There is no graphical edit environment assigned to window(10) because the window is not a graphic editor window.
Make sure that your current window is a valid graphic editor window.
If it is a valid graph editor window, contact customer service to investigate this issue.
I don't know how to assign a graphical edit environment to the window, besides I think I already created a graphic window. Why isn't it recongnized?
Thanks in advance
Renee
    Renee,
    Use geOpen(?window win1 ?lib "opamp090" ?cell "adc_sample_hold" ?view "layout_final") for example.
  • sai vardhan
    sai vardhan over 5 years ago
    *WARNING* (GE-2067): geComputeQueryBbox: There is no graphical edit environment assigned to window(385) because the window is not a graphic editor window.
    *Error* geqp: can't handle (-3.3125 >= nil)
    how to solve this problem in cadence? If you know please help me.
    Andrew Beckett over 5 years ago in reply to sai vardhan
    First of all, please read the forum guidelines. You've posted on the end of a 9 year old thread and it's not that obvious that your query is anything to do with the original post either.
    I don't know what you're doing - you've just given a warning and error message without indication of what your code (or even if you're using any code) is doing. It appears that geComputeQueryBbox is being called either with a window argument or with the default argument when the current window is not a layout/schematic/symbol window (or there is no current window). Because of that, it returns nil - and maybe some operation is then done which is using >= (geqp). However, this is pure guesswork on my part! If I'm right, you need to either pass a valid window or ensure that the current window (if relying on the default behaviour) is the right kind of window.
