  3. How to add a menu item to the export in CIW
  • Replies 12
  • Subscribers 150
  • Views 21217
venuuuuu
venuuuuu over 14 years ago
 hi all,
I need to add a menu item "Run GDS to Library" (Which writes out GDS files for all layout views in a library) to export in CIW.
Let me know how to do it .
    As suggested in the forum guidelines, please state which version are you using? This is particularly important in this case because the program launched is different between IC5141 and IC61
  • venuuuuu
     sorry for less information Andrew. My version is IC5141
    Actually, thinking about it, why do you need to do this? If you use File->Export->Stream and fill in the library name but leave the top cell name field blank, it already writes out all layouts into the stream file. See the documentation on the stream interface (<ICinstDir>/doc/transref/transref.pdf ) for more details.
  • venuuuuu
     hi Andrew,
    I saw your code on cadence online support .
    /* abWriteLibGDS.il
    Author     A.D.Beckett
    Group      Custom IC (UK), Cadence Design Systems Ltd.
    Language   SKILL
    Date       Mar 05, 2002
    Modified
    By
    To use this, Save a template from the File->Export Stream form,
    which contains any layer maps etc that you want to use. Then
    you can run the code by doing:
    abWriteLibGDS("libName" "/path/to/template/file")
    SCCS Info: @(#) abWriteLibGDS.il 03/05/02.10:52:04 1.1
    *     abWriteLibGDS(libName fileOrDPL [?viewName "layout"      *
    *                       ?suffix ".gds")                        *
    *    Writes out GDS files for all layout views in a library    *
    procedure(abWriteLibGDS(
        libName fileOrDPL @key (viewName "layout") (suffix ".gds")
        let((streamOutKeys)
            if(stringp(fileOrDPL) && isFile(fileOrDPL) then
                loadi(fileOrDPL)
            else
                streamOutKeys=fileOrDPL
            ) ; if
            foreach(cell ddGetObj(libName)~>cells
                when(ddGetObj(libName cell~>name viewName "master.tag")
                    abWriteCellGDS(libName cell~>name viewName streamOutKeys suffix)
                ) ; when
            ) ; foreach
            t
        ) ; let
    ) ; procedure
    * abWriteCellGDS(libName cellName viewName streamOutKeys suffix) *
    *    Given the library, cell and view names, and a DPL of the    *
    *     template file data, the suffix to apply to the files,      *
    *    write out a stream file. This is done by creating a new     *
    *  template file, and invoking "pipo strmout", and waiting for   *
    *                          the results.                          *
    procedure(abWriteCellGDS(libName cellName viewName streamOutKeys suffix)
        let((template fileName ipcId)
            streamOutKeys->libName=libName
            streamOutKeys->primaryCell=cellName
            streamOutKeys->viewName=viewName
            streamOutKeys->outFile=strcat(cellName suffix)
            streamOutKeys->errFile=strcat("PIPO_" cellName ".LOG")
            printf("Writing GDS for %s/%s/%s to %s\n"
            ) ; printf
            fileName=makeTempFileName("/tmp/writeCellGDS")
            template=outfile(fileName)
            fprintf(template "streamOutKeys='%L\n" streamOutKeys)
            close(template)
            ipcId=ipcBeginProcess(strcat("pipo strmout " fileName))
            ipcWait(ipcId)
            deleteFile(fileName)
        ) ; let
    ) ; procedure
    I need to attach this function as an item in  File->Export.
    You'll need to create a form to fill in some of the fields, and then use this as a callback to that form. There is plenty of coverage of writing forms in the documentation, and examples on COS and on this forum.
    Then  you'll need to add a menu. I would suggest not adding this into File->Export, although it could be done by taking the menus files in <ICinstDir>/tools/dfII/etc/tools/menus (look at the README file in there) and customizing it. Alternatively you could use hiCreatePulldownMenu() and hiInsertBannerMenu to add your own menu in the CIW.
    Hopefully that gives you enough pointers. I do not have the bandwidth to write it for you, and there are plenty of examples around that should allow you to get started.
  • venuuuuu
     hi Andrew,
     I done as u suggested in last post. 1st i created a form and fill it with fields(rundirectory, library). Then i created a menu in CIW. But when i running the script for form then CIW shows "nil" and one worning.
     procedure(gds()
      let( (form)
     if(boundp('CCSgdsForm) && CCSgdsForm then
          form = CCSgdsForm
        else
          form = CCScreategdsForm()
        ); if
        when(hiIsForm(form)
      enterString(
            ?prompts list("Enter rundirectory to gds ")
            ?form form
            ;?initProc t_initProcName
            ?doneProc "CCSgdsDoneProc"
            ;?formProc t_formProcName
            ?alwaysMap t
            ?cmdName "CCSgdsForm"
        ); when the form exists
      ); let
    ); procedure CCSmetBus
    procedure(CCScreategdsForm()
       let( (rundirectory librarys library form )
    librarys=ddGetLibList()~>name
            library = hiCreateCyclicField(
              ?name 'library
              ?choices      librarys
              ?prompt       "Library"
              ?value        car(librarys)
              ?callback     "CCSchangelibrary()"
    rundirectory=hiCreateStringField(
    ?name 'rundirectory
    ?prompt "Rundirectory"
    ?value  ""
    ?defValue "."
    ?callback "CCSchangeDirectory()"
    ); hiCreateStringField
     form = hiCreateAppForm(
              ?name 'CCScelltoGdsForm
              ?formTitle "Cell into GDS"
              ?formType     'options
              ?buttonLayout 'HideCancelDef
              ?fields list(list(library 0:0 200:30 50)
                    list(rundirectory 0:30 200:30 50) )
            ); hiCreateAppForm
         ); let
    );procedure
     procedure(CCSchangeDirectory()
      let( (origRundirectory)
        when(boundp('CCSgdsForm) && CCSgdsForm
          origRundirectory= CCSgdsForm->rundirectory->value
          CCSgdsForm->rundirectory->value = origRundirectory
          unless(CCSgdsForm->currentRundirectory == CCSgdsForm->rundirectory->value
            CCSgdsForm->currentRundirectory = CCSgdsForm->rundirectory->value
          ); unless
          applyEnterFun(form)
      ); let
    ); procedure
    procedure(CCSgdsDoneProc( done points "wgl")
      let( ( form )
          form   = CCSgdsForm
          if(done then
                form->currentRundirectory = nil
                  CCSgdsCB(
                 form->rundirectory~>value
           ); if done
        ); when form exists
      ); let
    ); procedure
    Then CIW shows:
    " (icfb) Syncing library list with the Library Manager."
    And I feel my form is not working properly. Please help me to do this.
  • venuuuuu
     hi Andrew,
                     I created a menu in CIW. but when I placed this program in .cdsinit for loading automatically,it doesnot work. Let me know suggestion on it.
    code is below.
      let( (item1   trPulldownMenu2  )
    item1=hiCreateMenuItem( ?name 'item1 ?itemText "gds to library"
                  ?callback "labels()"
    ;item2 = hiCreateMenuItem( ?name 'item2 ?itemText "Set lsw"
                  ;?callback "venu()")
    Menu=hiCreatePulldownMenu('trPulldownMenu2 "FPS2" list(item1 ) )
    hiInsertBannerMenu(window(1) Menu  0))
    OK, starting from this last question. You need to call ciwMenuInit() in the .cdsinit before you try to insert the banner menu.
    For the previous question, several issues:
    1. The gds() function is checking for the existence of a variable called CCSgdsForm, yet the function CCScreategdsForm() is creating a form called CCScelltoGdsForm. So it checks for the existence of it, and then creates a different form.
    2. Rather bizarrely gds() is calling enterString(). Why? Surely you want to use hiDisplayForm() instead? That will avoid having to have the function CCSgdsDoneProc at all.
    3. If you do that, you will need to create the form as a 'nonoptions form rather than an 'options form.
    4. The CCSchangeDirectory() function is also referring to the wrong form name.
    5. CCSchangeDirectory() is calling applyEnterFun() which wouldn't be necessary if this is done properly (i.e. without an enter function)
    6. When you create the form, you'll probably want to use ?callback to specify a function which is called when the OK/Apply button is pressed.
    I've not followed through or tried to debug the entire code - but it's a bit messed up, so I suggest you try to unravel things using the suggestions above first.
  • venuuuuu
     hi Andrew,
     I did the changes as you suggested in last post. But form appears  only, whenever layout window is opened. Without layout window I  get  nil  in CIW.  My code is below
     procedure(gds()
      let( (form)
          form = CCScelltoGdsForm
        else
        ); if
        when(hiIsForm(form)
      enterString(
            ?form form
            ?alwaysMap t
            ?cmdName "CCScelltoGdsForm"
      ); let
              ?name 'library
              ?choices      librarys
              ?prompt       "Library"
    ?name 'rundirectory
    ?value  ""
    ?defValue "."
              ?formType     'nonoptions
              ?buttonLayout 'OKCancelApply
              ?callback "abWriteLibGDS1()"
            ); hiCreateAppForm
         ); letprocedure(gds()
      let( (form)
        else
        ); if
        when(hiIsForm(form)
      enterString(
            ?form form
            ?alwaysMap t
      ); let
              ?name 'library
              ?choices      librarys
              ?prompt       "Library"
    ?name 'rundirectory
    ?value  ""
    ?defValue "."
            ); hiCreateAppForm
         ); let
    );procedure
        when(boundp('CCScelltoGdsForm) && CCScelltoGdsForm
          origRundirectory= CCScelltoGdsForm->rundirectory->value
          CCScelltoGdsForm->rundirectory->value = origRundirectory
          unless(CCScelltoGdsForm->currentRundirectory == CCScelltoGdsForm->rundirectory->value
            CCScelltoGdsForm->currentRundirectory = CCScelltoGdsForm->rundirectory->value
          ); unless
          ;applyEnterFun(form)
      ); let
    ); procedure CCSchangeMetBusWidth
    procedure(CCSgdsDoneProc( done )
      let( ( form )
          form   = CCSgdsForm
          if(done then
                  CCSgdsCB(
           ); if done
        ); when form exists
      ); let
    ); procedure
    procedure(abWriteLibGDS1()
    /* abWriteLibGDS.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Mar 05, 2002
    Modified
    By
    *                       ?suffix ".gds")                        *
     abWriteLibGDS(CCScelltoGdsForm->library->value "venus.il")
        let((streamOutKeys)
                loadi(fileOrDPL)
            else
            ) ; if
                ) ; when
            ) ; foreach
            t
        ) ; let
    ) ; procedure
    *                          the results.                          *
            ) ; printf
            close(template)
            ipcWait(ipcId)
        ) ; let
    ) ; procedure
    );procedure
          ); unless
      ); let
      let( ( form )
          form   = CCSgdsForm
          if(done then
                  CCSgdsCB(
           ); if done
        ); when form exists
      ); let
    ); procedure
    /* abWriteLibGDS.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Mar 05, 2002
    Modified
    By
    *                       ?suffix ".gds")                        *
        let((streamOutKeys)
                loadi(fileOrDPL)
            else
            ) ; if
                ) ; when
            ) ; foreach
            t
        ) ; let
    ) ; procedure
    *                          the results.                          *
            ) ; printf
            close(template)
            ipcWait(ipcId)
        ) ; let
    ) ; procedure
    1) what is the difference between options and nonoptions form
    2)Why do we need  CCSchangeDirectory(),CCSgdsDoneProc() in code.
  • venuuuuu
    hi Andrew,
    I did what you suggested in before post. I got it . But my form is appears when i opened a cellview. If  cellview is not present, then CIW(5141) shows "nil".  Why it is happening? My code is below
     procedure(gds()
      let( (form)
        else
        ); if
        when(hiIsForm(form)
      enterString(
            ?form form
            ?alwaysMap t
      ); let
              ?name 'library
              ?choices      librarys
              ?prompt       "Library"
    ?name 'rundirectory
    ?value  ""
    ?defValue "."
            ); hiCreateAppForm
         ); let
    );procedure
          ); unless
      ); let
      let( ( form )
          form   = CCSgdsForm
          if(done then
                  CCSgdsCB(
           ); if done
        ); when form exists
      ); let
    ); procedure
    /* abWriteLibGDS.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Mar 05, 2002
    Modified
    By
    *                       ?suffix ".gds")                        *
        let((streamOutKeys)
                loadi(fileOrDPL)
            else
            ) ; if
                ) ; when
            ) ; foreach
            t
        ) ; let
    ) ; procedure
    *                          the results.                          *
            ) ; printf
            close(template)
            ipcWait(ipcId)
        ) ; let
    ) ; procedure
    1) what is the need of  CCSchangeDirectory(),CCSgdsDoneProc in above cod.
    2) what is the difference between nonoptions and options form
