  3. assigning arrow key in bindkey
  • Views 16603
Rojalin
Rojalin over 14 years ago
Hii,
 I want to assign arrow key as one of bindkey.Can someone say how to use arrow key in hisetBindKey function??
  • lawlag02
    lawlag02 over 14 years ago
    Hi
    <Key>Left
    <Key>Right  .....  Up  Down
    regards
    lrlsk
  • dmay
    dmay over 14 years ago
    There is a great Unix utility called "xev" that is an X event viewer. In a terminal window run "xev" and you will see a little window pop up called "Event Tester". Move your mouse over the window and a ton of messages start scrolling by. The tool reports the events taking place over the window, so it will record every mouse movement. Take your hand off the mouse and press a key on the keyboard and you'll see some information like this:
    KeyPress event, serial 32, synthetic NO, window 0x5900001,
        root 0x1e6, subw 0x0, time 1199879666, (117,130), root:(991,688),
        state 0x0, keycode 102 (keysym 0xff53, Right), same_screen YES,
        XLookupString gives 0 bytes:
        XmbLookupString gives 0 bytes:
        XFilterEvent returns: False
    KeyRelease event, serial 32, synthetic NO, window 0x5900001,
        root 0x1e6, subw 0x0, time 1199879786, (117,130), root:(991,688),
    Notice there are two events, KeyPress and KeyRelease. In the third line next to the keysym code is the name of the key just pressed. I pressed the right arrow. Now try pressing the right arrow on the number keypad and you should see a name like: KP_Right
    Sometimes these names are different for other operating systems or keyboards, so it is a great debug tool as well as a key-identifyer tool.
    Derek
    And in IC615 it's even easier because in the new bindkey editor you can just press the key (or key combination) and it will fill in the key coding for you automatically.
