  3. bindkey to hide create instance menu
  • Subscribers 150
  • Views 14993
egxoner
egxoner over 14 years ago
hello
i use ic 6.15
i have written a skill function and pointed that function with a bindkey for putting a specific instance to the layout. i use leHiCreateInst() command to call the instance. but when i call my instance Create Instance menu pops-up. i want to hide the menu automatically. maybe with a command that i can add to my function.
i added hiiToggleEnterForm(leCreateInstForm) command to the end of my function but i didnt work.
  • dmay
    dmay over 14 years ago
    The problem is that the toggle command does not run until after the form finishes. To get around this, you can use the hiRegTimer command. This will submit a command to run some amount of time in the future:
    hiRegTimer("hiiToggleEnterForm(leCreateInstForm))" 1) ; In 1/10th of a second, toggle the form visibility
    leHiCreateInst()
    You could also use the same command to populate the form with your library/cellName/viewName:
    hiRegTimer("leCreateInstForm->libName->value = \"mylib\"" 1)
    hiRegTimer("leCreateInstForm->cellName->value = \"mycell\"" 1)
    hiRegTimer("leCreateInstForm->viewName->value = \"layout\"" 1)
    hiRegTimer("hiiToggleEnterForm(leCreateInstForm)" 1) ; In 1/10th of a second, toggle the form visibility
    leHiCreateInst()
    Derek
