  3. How to load streamin for files in a directory
  • Subscribers 150
  • Views 15603
venuuuuu
venuuuuu over 14 years ago
Hi all,
I need to load streamin for files in a directory to a library (library is specified by user). Give me your suggetions to do it.
And can i run LVS,DRC  to  a library.
  • venuuuuu
     Hi all,
     I write a code for this which works not properly. First I take files which contain .gds as suffi. my code is below.
     In the template File field, specify a file with path and save it. For example /template/file and click on Save button.
    procedure(CCSStreamoutFiles( dirPath tempFileOrDPL @key (suffix ".gds") )
        let((gdsFileList )
            if(stringp(tempFileOrDPL) && isFile(tempFileOrDPL) then
                loadi(tempFileOrDPL)
            else
                error("\n Specify correct parameter file ...")
            ) ; if
            gdsFileList=setof(x getDirFiles(dirPath) and(isFile(x) rexMatchp(suffix x)))
          foreach(filename gdsFileList
                CCSImportstreamIn(strcat(dirPath "/" filename) streamInKeys filename )
                   ) ; foreach
            t
        ) ; let
    ) ; procedure
    procedure(CCSImportstreamIn(gdsFile streamInKeys filename )
        let((template fileName ipcId)
            streamInKeys~>inFile=gdsFile
            streamInKeys~>primaryCell =car(parseString(filename ".gds"))
            printf("Writing streamIn for %s to %s/%s layout\n"
                filename libName streamInKeys~>primaryCell
                     ) ; printf
            fileName=makeTempFileName("/tmp/StreamIn")
            template=outfile(fileName)
            fprintf(template "streamInKeys='%L\n" streamInKeys)
            close(template)
            ipcId=ipcBeginProcess(strcat("nino strmin " fileName))
            ipcWait(ipcId)
            deleteFile(fileName)
        ) ; let
    ) ; procedure
     When i entered it in CIW
    CCSStreamoutFiles("/path/directory"  "/template/file")
    CIW shows :*Error* putprop: first arg must be either symbol, list, defstruct or user type -"/path/directory"
    First of all, you're going to confuse yourself if the function is called CCSStreamoutFiles when actually it does a Stream In not Out.
    The problem is because you've used ~> with a disembodied property list (e.g. streamInKeys~>inFile). If the left hand side is a list, it is important whether you use -> or ~>. In the case of a disembodied property list, you must use ->, otherwise if you use ~> it will apply ~> to each member of the list and return a list of the results.
    So change all the streamInKeys~>... to streamInKeys->...
    Whilst I'm at it, I see you're calling "nino strmin". Not sure why, because it should be "pipo strmin". "nino" is a program to do "netlist in, netlist out" (although in practice it only does a netlist import). It is the underlying program behind File->Import->CDL in IC5141 (it used to be used for some other languages too).
