  3. is it possible to disable printf output (ie stdout) of a...
  • Views 3758
is it possible to disable printf output (ie stdout) of a called function/procedure
ebecheto
ebecheto over 14 years ago
 It is rather a general question than a 'Custom IC' question, but the context is about :
foreach(mapcar c cdfGetInstCDF(css())~>parameters evalstring(c->callback||"" ))
such evaluation of callback functions output a lot of blabla
Reff = Rbar * s
Reff = Rbar
Reff = Rbar / m
... n-times.
Is it possible to wrap-up a function that would  disable printf. Something like
mute(printf("Do not echo that!"))
Or I don't know, a function that redirect sdtout temporary :
disableStdout()
enableStdout()
Thanks for any help. That would be a nice X-mas gift to me.
Regards
    Merry Christmas!
    Two solutions (one I just wrote, and one from some time ago):
    /* abMute.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Dec 22, 2011
    Modified
    By
    A macro to mute the output from printf() calls etc.
    abMute(printf("test this\n"))
    will produce nothing.
    Relies on SKILL's dynamic scoping, so will not work in SKILL++
    unless you do:
    inSkill(abMute(printf("test this\n")))
    SCCS Info: @(#) abMute.il 12/22/11.11:03:17 1.1
    (defmacro abMute (@rest body)
      `(progn
         (unless (openportp (getqq abMute nullport))
           (putpropqq abMute (outfile "/dev/null") nullport))
         (let ((poport (getqq abMute nullport)))
           ,@body
     And the second (put this in a file with a .ils suffix, since it is SKILL++ code):
    /* abRedirectOutput.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       Aug 12, 1998
    Modified
    By
    Call using abRedirectOutput(t) or abRedirectOutput(nil)
    to turn printing to CIW on or off.
    Note, this is SKILL++, so requires file to end in .ils
    SCCS Info: @(#) abRedirectOutput.ils 11/20/08.15:26:24 1.2
    /* going to define abRedirectOutput */
    (define abRedirectOutput nil)
    /* private variable containing port to /dev/null */
    (let (nullport)
    (procedure (redirect on)
      (if on
          (progn
           (unless nullport
                   (setq nullport (outfile "/dev/null")))
           (setq poport nullport)
          (progn
           (setq poport (inSkill stdout))
           (close nullport)
           (setq nullport nil)
      on)
    /* export it */
    (setq abRedirectOutput redirect)
