  3. Commands to convert Single path to multiple paths.
  • Views 15147
GiriBabu
GiriBabu over 14 years ago
 Hi all,
        Is there any command that converts single path to multiple paths. (like draw bus in turbo tool box) . Can i see file that contains commands for functoins in turbo toolbox.
     But drawing a bus is an interactive operation - it just shows the first path interactively. So not really sure what your objective is and what purpose you are trying to achieve.
    Also, which version are you using? There's a native Draw Bus in IC615 which is rather more powerful.
  • GiriBabu
      hi Andrew,
                     I have bus script which is formed by rod create path. So i want to make my bus is as like as bus in tubo toolbox. In that first one path is created and then it devided into multiple paths.
                     Can I chop the layer whithout selecting that layer(like tunnel option in Turbo toolbox)
               By the way thanks for helping how to get 12 from "12" in the last post.
