  3. MPP template name
  • Subscribers 150
  • Views 15286
MPP template name
sgrover
sgrover over 14 years ago
 Guys,I create a rod MPP, and after creating it, I want to know MPP template name from rod MPP object, e.g.,after I select MPP in layout, and then, dump its information, I don't see any back reference to original MPP template name? How do I get it? "path13" is path name not template name, how do I fetch its template/MPP name?
  \i rodGetObj(css())~>??
\t ("rodObj:211821300" name "path13" cvId db:198279212
\t     dbId db:198399496 transform
\t     ((0.0 0.0) "R0" 1.0) align
\t     nil numSegments 1 subShapes
\t     (db:198402136 db:198402712 db:198402748 db:198402784 db:198399424
\t      db:198399460
\t     )
\t     userHandleNames nil systemHandleNames
\t     ("width" "length" "lowerLeft" "lowerCenter" "lowerRight"
\t      "centerLeft" "centerCenter" "centerRight" "upperLeft" "upperCenter"
\t      "upperRight" "length0" "start0" "startCenter0" "startLeft0"
\t      "startRight0" "mid0" "midLeft0" "midRight0" "end0"
\t      "endLeft0" "endRight0" "lengthLast" "startLast" "startLeftLast"
\t      "startRightLast" "midLast" "midLeftLast" "midRightLast" "endLast"
\t      "endCenterLast" "endLeftLast" "endRightLast" "mppBBox" "chopHoles"
\t     ) chopHoles
\t     nil
\t )
  • skillUser
    skillUser over 14 years ago
    To the best of my knowledge there is no backward reference of a ROD MPP that tells us which template (if any) was used to create it. You might be able to deduce that from the subShapes information (or subParts, if present) though.
    Hope this helps,
    Lawrence.
    There is no record of the original template name.
