  3. Help on Changing all library names for via's
  • Subscribers 150
  • Views 1005
venuuuuu
venuuuuu over 14 years ago
hi all,
      I need to change the libraryname of VIA_22 from example to narendra.   I write following code for this.
  cv =geGetEditCellView()
examplevias=setof(x  cv~>instances (x~>libName=="Example"&& x~>cellName=="VIA_22"))
foreach(examplevia examplevias
examplevia~>libName="narendra"
    You need to change the master attribute of the instance; you cannot change the libName or cellName attribute. So you'll need to do a dbOpenCellViewByType() and set the result to examplevia~>master
