  3. Standcell layout scaling problem
  • Subscribers 150
  • Views 16740
heavenevil
heavenevil over 14 years ago
I am now doing a standcell library migrating from 90nm to 65nm, only thing I have is the 90nm cell layout, I don't want to draw by hand and I found one post about it http://www.cadence.com/forums/p/13074/19670.aspx.
Andrew gave some code, but I never learned skill so I don't know how to change it, even don't know how to run it, can anyone give me some hint? Thanks a lot
  • heavenevil
    I've tried your code by run load("abscale.il") in CIW, and returns T.
    Then I open the layout I want to scale in CIW and use command cv = geGetEditCellView() to get the cell view ID, 227684396
    Then I run: abScaleAllObjects 227684396 0.6
    but return *Error* dbGetq: Object is not a db/dd object. - 227684396
    So what's the problem? I have the layout .cdb file, this is a layout others done by hand.
    Regards
    Li
    Hi Li,
    You can't just pass a number to the function. You have to give it the database ID of the cellView. You can't cut and paste the database ID and re-use it - all you see is the "print representation" when displayed.
    You'd have to use:
    abScaleAllObjects(cv 0.6)
    And cv contains the result of geGetEditCellView() as you typed it above.
  • heavenevil
    Thank you so much! Your code works! Great! Just a short question, now I have the scaled layout in 90nm, how can I export them to 65nm? I tried to copy the layout files to 65nm, but a lot of layers missing, thanks, I'm totally a new learner.
    You'll probably need to change the layer number of the shapes to the layer number in the new process. So you'd need a bit of code which knew about the mapping of the old layer numbers to new layer numbers. You can access and modify the layer number for a shape using shapeId~>layerNum
    Alternatively you could stream it out using the old layer map file, and stream in with the new. But that's a bit clunky.
    Or you could contact Cadence about accessing Virtuoso Layout Migrate, which is a tool designed for this purpose (which will do a whole lot more than simplistic scaling of the data and layer translation; it can ensure that the resulting design is DRC clean and handle differing scaling on different layers).
  • msakib
    msakib over 11 years ago
    Hi. I am looking for the script  abscale.il. I was not able to find it.
    Thanks, Sakib
