  3. About View Level Functions
  • Subscribers 150
  • Views 16451
Adhil
Adhil over 14 years ago
hey guys!!
 I was exploring the skill user manual, and i came across "View Level Functions". I would be thankful to anyone who could elaborate
1. What these functions do.
2. how they can be useful.
I was also trying to test some of the functions in the following manner
cv = geGetEditCellView()
geGetAllAreaViewLevel(cv)
however, I got the following errors.
Error* geGetAllAreaViewLevel: argument #1 should be a window type (type template = "w") - db:0x1427bf12
Loading verilogI.cxt
Can anyone explain why this is so, I am using IC6 latest.
Adhil.
    Adhil,
    The functions (which correspond to the  View->Area Display menu in VLS) allow you to alter the start and stop display level for an area of the design, rather than being applied to the entire design (as set via the Options->Display form). This you can keep everything at level 0 (just instance boxes), but show full depth (or whatever for one or more regions of the layout).
    The reason why it failed was quite clearly described in the error message - you gave it a cellView ID, but it is expecting a window ID. So you'd need to pass something like the result of hiGetCurrentWindow() to the function instead. Unless you've set an area, it will return nil (but you could always use the geSetAreaViewLevel function).
    There's also the ge.*InstViewLevel functions which allow the view level to be on specific instances. There's no UI for this (for some reason), but I wrote this SKILL function many years ago to allow me to easily toggle the view depth on selected instances:
    /* abToggleSelInstView.il
    Author     A.D.Beckett
    Group      Structured Custom, Cadence Design Systems Ltd
    Machine    SUN
    Date       Apr 22, 1993
    Modified   May 10, 2004
    By
    Function to toggle the Inst View level on selected objects
    between 0 and 20.
    abSetInvSelInstView() will set the depth on everything except
    the selected instances.
    abDeleteInstView() will delete all selected instance views.
    SCCS Info: @(#) abToggleSelInstView.il 11/20/08.15:26:21 1.2
    (procedure (abToggleSelInstView)
      (prog (depth win)
    	(setq win (hiGetCurrentWindow))
    	(foreach inst (geGetSelectedSet)
    		 (if (equal (dbGetq inst objType) "inst")
    		     (progn
    		      (setq depth (secondElement (geGetInstViewLevel win inst)))
    		      (if depth
    			  (geDeleteInstViewLevel win inst)
    			  (geSetInstViewLevel win inst 0 20)))))))
    (procedure (abSetInvSelInstView)
      (let (win selSet cv)
           (setq selSet (geGetSelSet win))
           (setq cv (geGetEditCellView win))
           (foreach inst (dbGetq cv instances)
    		(unless (or (equal (dbGetq inst objType) "mosaicInst")
    			    (member inst selSet))
           (foreach mosaic (dbGetq cv mosaics)
    		(unless (member mosaic selSet)
    			(geSetInstViewLevel win mosaic 0 20)))
           t
    (procedure (abDeleteInstView)
      (let (win cv)
    		(unless (equal (dbGetq inst objType) "mosaicInst")
    			(geDeleteInstViewLevel win inst))
    		(geDeleteInstViewLevel win mosaic))
           t
  • XinjiePI
    XinjiePI over 12 years ago
    Thanks for your information.
    Here I use geSetInstViewLevel() to set specific instance view level at 0 0 to want hide this instance. And then I am assuming that I can change window display level from 1 to 32 and that instance will not display.
    However, this is not working, the one I already set as 0 0 still display on 1 32.
    I am wondering if there is something I made mistake.
     Xinjie
    Xinjie,
    There appears to be a bug where the inst view level is only being honoured if it is greater than the display stop level (and I don't think the inst start level works at all). This is discussed in CCR 769449 - and fixing this was discussed as part of that CCR. You should contact customer support and get a request to fix this filed on your behalf (duplicating the CCR number that I mention).
  • XinjiePI
    Got it. Thanks Andrew.
    Xinjie
