  3. Adding menu entries to ADE L window
  • Views 17325
ChrisEAS
ChrisEAS over 14 years ago
While migrating some SKILL code from Cadence 5 to Cadence 6 I'm encountering problems with adding menu entries. On Cadence 5, I was able to add a menu entry to the Analog Artist window by using it's name "analogArtist-schematic":
 deRegUserTriggers("analogArtist-schematic" ... )
However, in Cadence 6 this name seems not to correspond to the ADE L window anymore. Which is the preffered way of including menu entries into ADE L within Cadence 6?
Cheers, Chris
    Chris,
    That never was the ADE window. That's the viewType of the schematic corresponding to the ADE window - i.e. the window you launched ADE from. That should still work - in fact I just tried it using this (very old) code:
    /* abAddArtMenus.il
    Author     A.D.Beckett
    Group      Structured Custom, Cadence Design Systems Ltd.
    Machine    SUN
    Date       Dec 09, 1996
    Modified
    By
    Method to add menus to artist simulation environment
    in 4.4
    SCCS Info: @(#) abAddArtMenus.il 11/20/08.15:26:09 1.1
    *                  (abAddArtMenusCreateMenu)                   *
    *       Create a dummy menu, just to show the principle        *
    (procedure (abAddArtMenusCreateMenu)
      (let (item1 item2)
           (setq item1
                 (hiCreateMenuItem
                  ?name 'item1
                  ?itemText "Item 1"
                  ?callback "printf(\"Item1\n\")"))
           (setq item2
                 (hiCreateMenuItem
                  ?name 'item2
                  ?itemText "Item 2"
                  ?callback "printf(\"Item2\n\")"))
           (hiCreatePulldownMenu
            'abArtMenu
            "Test"
            (list item1 item2)
    *                     (abAddArtMenusTrigger args)                      *
    *  Define a post-install trigger function for analogArtist-schematic   *
    * to install user defined menus in the artist simulation encapsulation *
    *                               window.                                *
    (procedure (abAddArtMenusTrigger args)
      (let (session sevWindow)
           /* get hold of the session - note sevSession is undocumented */
           (setq session (sevSession (getq args window)))
           /* and then the simulation window associated with the session */
           (setq sevWindow (getq session window))
           /* when there is a window associated, and the action is to install */
           (when (and sevWindow (equal (getq args action) 'install))
                 /* create menu if it doesn't exist */
                 (unless (boundp 'abArtMenu) (abAddArtMenusCreateMenu))
                 /* unless the menu is already there */
                 (unless (member 'abArtMenu
                                 (hiGetBannerMenus sevWindow))
                         /* insert it in right most place */
                         (hiInsertBannerMenu sevWindow abArtMenu
                                             (length (hiGetBannerMenus sevWindow)))
    Need to install as a post install function
    deRegUserTriggers("analogArtist-schematic" nil nil 'abAddArtMenusTrigger)
    A cleaner way (which could also be done in IC5141) is to define a menus file. Create a menus/spectre.menus file looking like this:
    ; Load the standard menus file
    load(prependInstallPath("etc/tools/menus/spectre.menus"))
    ; Identical to the IC614/IC615 menus files, but with "Custom" added.
    ; Note that the & in the names indicates the following char is the
    ; accelerator key
    (sevSetMainWindowPulldownMenus
      (let (menu)
       menu = `(
                    "S&ession"
                    "Set&up"
                    "&Analyses"
                    "&Variables"
                    "&Outputs"
                    "&Simulation"
                    "&Results"
                    "&Tools"
                    "&Custom"
                    "&Help"
        when( envGetVal("adexl.launchFromTest" "showMenu")
            menu = cons("&Launch" menu)
        menu
    ; Add to the existing menus, rather than "setting". Better than making this
    ; a copy of the built-in default menus and then hacking - much more likely
    ; to stay in sync this way.
    (sevAddMenuItemLists
      (lambda
       (session name)
       (case
        name
        ; Define Custom menu
        ("&Custom"
           ("item&A" ?callback (fnA ',session))
           ("item&B" ?callback (fnB ',session))
           ("item&C" ?subMenu t)
        ("item&C"
           ("itemC&1" ?callback (fnC1 ',session))
           ("itemC&2" ?callback (fnC2 ',session))
    Hopefully that gives you a clue as to alternative ways. This second approach also works when ADE is launched directly from the CIW, or by double-clicking a state cellView (which the other deRegUserTriggers way did not, even in IC5141, because it's really a schematic sub-app trigger).
  • ChrisEAS
    I knew about the menu files. However, I wasn't really sure about which of the two is the cleaner way. Will go for the menu file now.
     Thanks for the swift reply. Chris.
  • ChrisEAS
    I'm feeling a bit uneasy about the menu file solution. What happens if there are other parties manipulating the menu file, especially when distribution the solution to a customer. I'm afraid this may clash somehow. Especially since the menu is not just added to the end, but the whole list of menu entries is specified literally. Isn't there another non-interfering solution?
     Chris
    Chris,
    You potentially could use the
    asimenv.startup sessInitTrigFunc  string  ""
    .cdsenv setting, but again, that can only be a single function.
    There's a long-standing request for a trigger-based mechanism to do this - it can be done right now, but uses private functions (although that approach won't work with ADE XL).
    Best to contact customer support over this to come up with a more extensible way of doing this.
