  3. How reduce amount of zeros past comma, after using callback...
  • Views 5435
How reduce amount of zeros past comma, after using callback procedure.
TiNat
TiNat over 14 years ago
 Hello. I design my own library of elements and attach to each element file with callback
procedure. In my process grid resolution is 0.05 mkm. And in procedure I check if the geometrical
sizes lies in grid and transform them if not,  using the following code:
l_temp = round(1e+6*evalstring(cdfgData->l->value)*100)-fix(round(1e+6*evalstring(cdfgData->l->value)*100)/10)*10
if(l_temp<5.0 then addsegml = 0.0 else addsegml = 5.0)
cdfgData->l->value = sprintf(ll,"%.2g" fix(round(1e+6*evalstring(cdfgData->l->value)*100)/10)*10+addsegml)/(100*1e+6))
i.e. the length 0.367u will be transfotm to 0.35u.
But I have following problem:
when I enter the length less than 100u, there are no problems, but when I enter length more than 100u
the result transformed to 100.00000u. Such amount of zeros is not pleasant. I assume that I need enter some environment varable in .cdsenv or .cdsinit, but I don't know what. Who can help me, how I can avoid such problem.
Regards.
    You might want to use aelSuffixNotation() instead of using sprintf. So for example:
    value=100u
    aelSuffixNotation(value 6) => "100u"
    The 6 is to say that there should be 6 significant digits - it is to stop 100.01u rounding if there's a default of 4 significant digits. You can choose how many you want.
    I'd also recommend using cdfParseFloatString() instead of evalstring. If somebody has unwittingly entered "exit" as the value of the length of the transistor, you wouldn't want your callback causing virtuoso to exit!
