  3. How to detect "pcell eval failed" without instantiating...
  • Subscribers 150
  • Views 4619
How to detect "pcell eval failed" without instantiating a pcell?
Niveena
Niveena over 14 years ago
Hi, I need to find pcells that have "pcell eval failed" errors in a library, without instantiating the pcells in virtuoso. Is there any variable or parameter that holds this pcell error status, so that I can check the value of this variable through skill code? Waiting for your reply. Thanks, Niveena
    The marker is on the pcell subMaster (i.e. the variant), which will only be created by instantiation. Given that the failure may only arise when particular combinations of parameter values are given, it really only makes sense to be produced by virtue of instantiation.
  • Niveena
    Andrew, thanks for the quick reply. My intent was to QA my library in order to ensure no such "pcell eval failed" errors exist while instantiating a cell, using skill code. So in my skill code I ll have to instantiate a pcell and then check the log file for any errors. Is that right?
    You don't have to check the log file; you could check the instId~>master and check for any markers. I can't remember whether these end up as marker objects in IC61X, or whether they are still shapes on the marker/error layer purpose pair - either way they are pretty easy to detect programmatically.
  • Niveena
    Well Thanks once again. I can check that .
